04-19-2013, 09:37 AM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Hayden
| Brushed motor capacitors
I recently purchased a Novak Fifty Five. I searched and searched and finally found info on here for what springs and brushes to rebuild it with. But i have one problem.. I know when it was new, it comes with 3 capacitors installed from the factory. Mine has no capacitors on it. Does it require these or not... If so, does anyone know what capacitors they are, or were to get them.... Thanks In Advance
04-19-2013, 09:44 AM | #2 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Brushed motor capacitors
Those Capacitors are for AM/FM Radio interference only. If you are running a 2.4 Radio you don't need them, if you are using an AM or FM Radio you need them to reduce radio interference.
04-19-2013, 03:44 PM | #3 |
OP....there are a couple of recent threads discussing what caps to use. Also, yes, you don't "need them" if running 2.4ghz, but they also DON'T hurt anything. It may also reduce issues with others running close to you that do have a AM or FM radio. There is also a stickie in this forum on motors that cover caps on motors. BTW, some caps are actually on a small PC board on the end of the motor, thus easy to miss. |
04-20-2013, 12:02 PM | #4 |
Thanks, I am running a futuba 4pl setup so I don't need them. Everyone I crawl with uses 2.4ghz
Brushed motor capacitors - Similar Threads | ||||
Motor capacitors? | mhuffman_81 | Electronics | 2 | 02-18-2010 02:40 PM |
Motor capacitors? | tjcrawler | Electronics | 4 | 07-30-2009 08:17 AM |
Capacitors On The Motor | wheely king | Newbie General | 3 | 02-25-2008 05:24 PM |
motor capacitors | nosduj | Electronics | 2 | 08-03-2007 08:32 PM |
New Motor. Need Capacitors? | dkelley383 | Electronics | 4 | 02-21-2006 09:40 PM |
