04-24-2013, 04:14 PM | #1 |
Pebble Pounder Join Date: Apr 2005 Location: wellington,co
| Battery ?
Just bought a battery used. Its 2000 1cell lipo. I put it in my wraith and blew out receiver. At least it blew out the steering part of the receiver . Then I tried the battery and one of my other ones and it actually was starting to sizzle so I have discarded the battery. Being that it was a one cell with that have something to do with it I'm pretty new at this any info would help thanks Sent from my DROID BIONIC using Tapatalk 2 |
04-24-2013, 04:47 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
| Re: Battery ?
Your doing something wrong. One cell is 3.7 volts, your average NIMH pack is 7.2. So I'm sure you wrong about the cells. It sounds like your may have a short somewhere or perhaps you soldered the connectors on wrong. Possibly you charged it wrong, do you have a lipo charger? Did you set the charger correctly? Does your esc have lipo shut off or does it need to be programmed for the correct # of cells. Most likely it's something your doing but the first thing you need to do is figure out the correct # of cells.
04-24-2013, 06:05 PM | #3 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
Pics would help if u are able to upload some!
04-24-2013, 06:07 PM | #4 |
Agree with bukwylde ^ can be many diff things. Just need to know a little more info if possible to try and help figure it out!
04-24-2013, 06:53 PM | #5 |
| Re: Battery ?
Did you connect the battery direct to the RX? Likely not, thus, whatever battery you connected would power the ESC which would then power the RX with a safe voltage pretty much REGARDLESS of the battery voltage. Now, if you said the ESC died, then I would say you may have reversed the polarity of the pack vs. the ESC. Yes, pictures would help. |
04-24-2013, 07:10 PM | #6 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Given that receivers & servos run on 5v+ and ESCs use even more, I'd guess something else is going on. Your battery, if it is indeed 1 cell, won't put out any more than 4.7v. More details and/or pics would be very helpful.
Battery ? - Similar Threads | ||||
Battery question...yes, I read the battery thread...twice... | MikeTJ | Losi Micro-Rock Crawler | 14 | 06-07-2011 07:44 PM |
UK Version please - LOSB0862 Battery Charger & Battery. | newth | Losi Micro-Rock Crawler | 7 | 05-26-2010 01:38 AM |
Finding bad battery cells in a battery pack. | ToTheMAXXcrawler | Electronics | 9 | 02-04-2010 10:14 AM |
