04-28-2013, 11:58 AM | #1 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
| dead fxr?... what just happened?
my setup: wraith tekin fxr, 35t. castle bec to my rx, ss, winch, and lights. fully charged 3s, 3300, 35c I've been running this current setup for about 2 -3 weeks. Until about a week ago I had always used 5000mah nimh power. But I recently picked up a balance charger and some lipos and have been testing them out. I had a good day and a half of lipo runs, and then... Last night I plugged my fresh 3s into my ecs/bec harness. I heard a few little pops and crackles, then saw a small amount of smoke before yanking the battery. I had no idea what had just happened so I just left everything alone and went to bed. Today I've looked at it a bit more. first I plugged everything back together and plugged my battery in. My rec was getting power (through my bec) but my fxr will not turn on. I though maybe my little connection harness was faulty, so I de-soldered the harness and inspected the connections. It seemed there was a bad connection in one of the plugs that I had been using (not one that I had soldered one that came with my wraith rtr). I thought to myself "well that's the problem I just need to solder up a new harness." It seems that's not the issue though, because when I plug a 3s battery directly into my fxr, the fxr still does not turn on. So, have I fried this esc? If so, how? What happened? And how can I avoid this in the future? Also, if I do indeed need to replace the fxr should I replace it? Or go brushless? Sorry for the long story, Thanks in advance for any input. Last edited by bvrc; 04-28-2013 at 01:29 PM. |
04-28-2013, 12:27 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
| Re: dead fxr?... what just happened?
sounds like you need a new esc... popping sounds + smoke are never a good sign! Check all your wiring... check it again! Did you plug the battery in backwards? ( ive seen dumber shit happen)!
04-28-2013, 12:49 PM | #3 |
yeah I'm researching new esc's and systems now. I want to have my rig ready for a g6 next weekend (i need to order something tonight so I can get it mid-week). I've double checked all the wiring, and like I mentioned above I think there was that one bad connection in my harness that goes from my battery to both my bec and esc. I'll be certain to make clean connections when I rewire. I guess I'm still confused though about what happened. If I did some how cross wires, why didn't my bec fry too? I'm not the smartest or most experienced with all this, so it wouldn't surprise me to find out I did something wrong... Could it have been something with my lipo? The way I charged it or something? Lipos are new to me, so I worried that had something to do with it... Last edited by bvrc; 04-28-2013 at 01:30 PM. |
04-28-2013, 12:56 PM | #4 |
Newbie Join Date: Jun 2008 Location: CEN*CAL
get a hold of tekin tell them what happened and they will want you to send it in.....not to long ago i had my RX8 go "poof" when i changed my lipo cutoff from 4s to 6s. sent my esc in and they told me there was nothing rhey could do but give a discount on a new one...so i told them to shove it and bought a CASTLE!!!!!!!
04-28-2013, 01:00 PM | #5 | |
| Re: dead fxr?... what just happened? Quote:
04-28-2013, 01:02 PM | #6 |
Tekin does not replace anything period! They make some of the smoothest esc's but when they break.... your shit out of luck!
04-28-2013, 01:09 PM | #7 | |
I am using the capacitor on the esc. I installed it just as directed in the manual. The esc looks fine, just doesn't turn on. If I crossed wires somehow, wouldn't my bec have fried as well? maybe I'm not understanding how my bec works? | |
04-28-2013, 05:34 PM | #8 |
how is the bec wired in?
04-28-2013, 07:20 PM | #9 | |
Pebble Pounder Join Date: Jan 2008 Location: New Bedford MA. USA
04-29-2013, 05:19 AM | #10 |
| Re: dead fxr?... what just happened? |
04-29-2013, 05:47 PM | #11 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
You didn't feed it enough tacos. It sounds like a big problem that is going to end up with you getting a new ESC. Maybe you forgot to change the cut-off and it overloaded.
04-30-2013, 07:33 PM | #12 | |
I ended up just ordering another fxr. I need something by the end of this work week so I can have a running rig for sunday's g6. Here's a link to the my truck if anyone is curious. http://http://www.rccrawler.com/foru...ith-story.html | |
04-30-2013, 08:11 PM | #13 |
I would get the hotwire too so you can see what you are setting it at and not just hoping that it blinked the right number of times. I have Castle ESC's with the castle link and I love being able to see the actual setting. That, and the possibility to run a 4s lipo too. |
04-30-2013, 08:15 PM | #14 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
The voltage cutoff has nothing to do with whether or not it fried because you plugged in a 3S battery. The FXR can handle the voltage from a 3S regardless of what the LVC is set to. LVC is to protect the battery not the esc. Chances are somewhere there was a connection between + and -.
04-30-2013, 08:24 PM | #15 |
That's all I could come up with at the time I was typing. Connection between + & - = poof, instant weenie roast.
04-30-2013, 09:22 PM | #16 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Just mailed me a new one...twice Chances are you fried the BEC also Last edited by Postclanker; 04-30-2013 at 09:27 PM. | |
05-01-2013, 07:16 PM | #17 | |
05-01-2013, 07:18 PM | #18 |
05-01-2013, 07:56 PM | #19 |
Rock Crawler Join Date: Feb 2012 Location: OC
I found out the hard way that while the Tekin FX-r is a fine ESC, it is particularly sensitive to reverseing the polarity and it's BEC can only run a rx, and fan. Plugged in an FX-r(brand new) backwards for about 3-5 seconds and poooffff meltdown....i bet thats what happen to you, the BEC didn't fry cuz its probably not as sensitive, or has a cut off to avoid damage......i would monitor that BEC I have a feeling it might be damaged too but it will be harder to detect, stick a volt meter on it to make sure...i would, dont fry a servo or rx. I disagree about Tekin's Customer Service, I think they are the best I have never had an issue denied, they are always good to me. Explain what happened and all they can tell you is "No", I would follow all their procedures to return an ESC, and do it...... Good Luck. Last edited by TheAxialNut; 05-01-2013 at 08:00 PM. |
Tags |
fxr dead |
dead fxr?... what just happened? - Similar Threads | ||||
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
Dead Tekin FXR | SULFUR | Electronics | 12 | 06-26-2008 06:20 PM |
