Thread: Weird fxr pro issue
Old 05-08-2013, 06:10 PM   #1
Default Weird fxr pro issue
So thought my Motor was junk which it isn't in good shape anyways so bought new motor and still same problem. Problem is that I have full brake in reverse but when in forward has little to no brakes at all now I've manually reprogrammed the fxr multiple times to have instant brakes when off throttle in both forward and reverse. And it just started outta no where's was out crawling and good all day till just the end and bam no brakes in forward. Anyone had this issue? And can it be fixed?
bigred22 is offline   Reply With Quote
Old 05-08-2013, 06:56 PM   #2
Default Re: Weird fxr pro issue
try the hotwire....
Postclanker is offline   Reply With Quote
Old 05-08-2013, 08:59 PM   #3
AddictedtoRC1's Avatar
Make sure you have Push Control off and your drag setting is all the way up. Like Postclanker said a Hotwire will be your best bet. The Neutral Deadband Width may need opened up a little as well.
AddictedtoRC1 is offline   Reply With Quote
Old 05-09-2013, 05:11 AM   #4
Did you do a new throtle calibration?
arny is offline   Reply With Quote
Old 05-09-2013, 06:30 PM   #5
No I didn't recalibrate throttle and push control is off with drag cranked
Old 05-10-2013, 08:44 PM   #6
Fixed it had the throttle profile on my radio at 125% in forward set back to 100% and bam back to Normal
Old 05-10-2013, 09:28 PM   #7
. Nice...simple fix
Happy crawling Mr. Red
Weird fxr pro issue - Similar Threads
weird controler issue puddin Axial Wraith 0 03-10-2013 11:25 AM
Weird servo issue Nimyad Electronics 23 02-13-2013 10:05 AM
Mamba Max Pro Weird Issue ik632 Electronics 14 10-10-2012 02:48 PM
weird issue with Dx3e... R/CMaxximus5.0 Electronics 10 05-01-2010 06:56 PM
Weird Quark issue? RXcrawler Electronics 3 05-07-2007 11:01 AM
