Thread: Tekin B1-r Question
Old 05-11-2013, 06:58 PM   #1
Default Tekin B1-r Question
For some reason I can't get my new b1-r to sync up with my flysky gtb correctly. When i go through the set-up it won't confirm my trigger pulls unless i push forward for acceleration and pull back on brake. This is a problem because i'm using two esc and the other one works fine, so when i pull the trigger the front and rear wheels go in separate directions.
builder is offline   Reply With Quote
Old 05-12-2013, 07:18 AM   #2
Default Re: Tekin B1-r Question
Make sure the internal setting in each ESC is set correctly (not reversed), then calibrate.
Once that is done, you may need to swap the "ESC to motor wires" on one ESC so that motor rotation is correct. Brushed motors have no issues with swapping the motor wires to change motor direction.
Charlie-III is offline   Reply With Quote
Old 05-12-2013, 06:10 PM   #3
How do you make sure the esc isn't reversed internally ?
Eh i think my esc is fried :( doesn't beep or work in forward or reverse.
Tekin B1-r Question - Similar Threads
Tekin RS question DRTMI Electronics 2 02-17-2013 01:45 PM
Question about my Tekin FX-R warfish Electronics 6 05-14-2011 09:51 PM
Tekin R1 ESC. question.. bjerk1 Electronics 1 10-08-2009 06:11 PM
Tekin FX-R question jeffc Newbie General 2 01-04-2009 02:36 PM
Tekin r2 question badltl510 Electronics 1 03-14-2007 09:24 PM
