06-03-2013, 06:16 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Carrollton, IL
| brushless combo setup help
I am completely lost when it comes to brushless but want to make a mud skimmer for local mud bogging comps so I need help with cheap brushless combos like from hobbyking thanks I want a fast truck that could skim or almost skim across mud Would this motor and esc work cuz I have no idea on brushless I also want to run 2s or 3s lipos. thanks HobbyKing Brushless Car ESC 45A w/ Reverse TP540-11.5T 3350kv Brushless R/C Car Motor w/sensor and maybe this motor if you guys think it is fast enough to skim mud or some cheap motor that will skim across mud thanks Last edited by scoggdog13; 06-03-2013 at 06:27 PM. |
06-03-2013, 06:24 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: brushless combo setup help
Links don't work.
06-03-2013, 06:27 PM | #3 |
fixed it thanks
06-03-2013, 06:35 PM | #4 |
I would probably go to a 60 amp esc, the motor would probably do alright on 3s but would probably too sow on 2s.
06-03-2013, 06:36 PM | #5 |
would there be a better faster motor u would have in mind?
06-03-2013, 06:42 PM | #6 |
Look at the comments about the motor below the tech stuff. For what you are wanting to do, wheel speed is key, so maybe a 4200-5000Kv model. But if you go more motor you are going to have to get a higher amp esc, Some of their motors list in the specs the motors max amp draw, so base the esc on that.
06-03-2013, 06:51 PM | #7 |
ok thanx for the info
06-03-2013, 06:53 PM | #8 |
How about this motor it says max amps 20A XK2040-4500KV Brushless Inrunner or maybe this one XK2435-4600KV Brushless Inrunner |
06-03-2013, 07:20 PM | #9 |
Rock Stacker Join Date: Feb 2013 Location: NW
Just pick up a used traxxas vxl setup......it will do what u want on 3s no prob
06-03-2013, 07:20 PM | #10 |
| Re: brushless combo setup help are you talking about the vxl setup? if so it is way out of the price range
06-03-2013, 08:17 PM | #11 | |
| Re: brushless combo setup help Quote:
06-03-2013, 08:20 PM | #12 | |
06-03-2013, 08:24 PM | #13 |
It says the motors max draw is 37 amps, so you could use the 45a, but for an extra $8 you can get a 60a. Turnigy TrackStar 1/10th Scale 60A Car ESC Version 2 Whoops, that one is sensorless. |
06-03-2013, 08:25 PM | #14 |
yup i see that would be better thank you for everything
06-03-2013, 08:29 PM | #15 |
Here is a sensored one,http://www.hobbyking.com/hobbyking/s...s_Car_ESC.html, but you would be limited to 2s so I would choose a faster motor like this, Turnigy TrackStar 6.5T Sensored Brushless Motor 5485KV |
06-03-2013, 08:33 PM | #16 |
If you could swing a little more towards the esc, take a look at this one, Turnigy Trackstar 1/10th 60A Sensored/Sensorless Car ESC.
brushless combo setup help - Similar Threads | ||||
novak goat brushless combo or rooster brushed combo? | killerklod007 | Electronics | 6 | 04-08-2009 08:35 AM |
