06-07-2013, 10:39 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
| Novak crawler brushless motor
I am VERY new to crawlers. Just picked up a wraith kit and am in the process of building it. I am taking my time with it and I am doing basic upgrades right out of the box. It has all metal gears in t-case, and a few other do-dads. I am gearing for very slow moving with a 87/13. I was looking at the Novak 21.5t brushless sensored motor and was wondering if it was worth my while. I am not trying to spend $150 on a tekin ROC of I don't have to. I will be using a 70a dynamite esc and if that doesn't work well I may step up to a mamba max pro. Any thoughts on a high torque brushless crawler motor?
06-07-2013, 11:58 PM | #2 |
Quarry Creeper Join Date: Jul 2011 Location: Sullivan
| Re: Novak crawler brushless motor
from what I have gathered roaming around the forums here a lot of people say away from Novak elect. if I was going for another motor look at Holmes hobbies. John has some great motors and they are very reasonably priced. also for a lot more info than you can think of go down to the wraith forum and there is a sticky that Harley has on motors and gearing its well worth the read on my wraith I went with a Holmes hobbies 55t torque master handwound |
06-10-2013, 02:18 AM | #3 |
The Novak motors seems okay, but for slow crawling use a brushed motor!
06-10-2013, 03:13 AM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I have a Hobbywing Xerun 21.5T BL sensored motor in mine, however i'm geared lower than yours...93/12 with 43/13's. It crawls great. However, if you want it to wheel like a comp crawler, then you have to go with a brushed motor.
06-11-2013, 01:15 PM | #5 |
Timbuk2\13.5\2S in my Wraith currently, has worked fine for me. THe ESC makes a few R2D2 sounds at low RPM but overall feels nice and smooth, and good top end. No issues with the motor at all - feels like my other brushed setups really. I've run other Novak motors with various ESCs in my speedier set-ups without issue. Ironically, I'm bumping up to a 3100kv ROC motor set-up, but only as I'm looking for a little more speed. the Novak is going over to my SCX actually where I can actually get my fat fingers on the programming buttons. |
06-11-2013, 03:16 PM | #6 |
For less than $200 you can have a mmp and a 3656sd.
06-11-2013, 03:19 PM | #7 |
OSRC...what gearing are you running and how much run time do you get?
06-12-2013, 07:26 AM | #8 |
Unknown on the gearing. Second owner, and know it's converted to 32p but didn't bother to count. Can let you know when I tear it down (tonight most likely, roc's coming tomorrow). As far as runtime, I've never dumped a battery yet. Run 4000mah packs and have wheeled for 45 minutes without dumping. Slower technical stuff with a few full throttle bursts. Not sure if that helps or not. |
06-13-2013, 05:25 AM | #9 |
16/54 is what was in there after tearing it down.
Novak crawler brushless motor - Similar Threads | ||||
Novak Crawler Brushless Motor with MM | DirtNap | Electronics | 2 | 02-06-2008 09:05 PM |
Novak Super Sport Brushless ESC + Novak Crawler Motor | Scattman | Electronics | 10 | 03-13-2007 08:27 PM |
Novak brushless crawler motor | Frosty619 | Electronics | 1 | 08-17-2006 10:33 PM |
