06-21-2013, 11:30 AM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
| Timbuk2 wraith question.
I finally got my wraith together and I used the Novak timbuk2 "wraith edition" combo. It's working great except for if I'm at full lock on the steering and attempt to give it throttle its glitches out and does odd things. The combo came with a capacitor that has a plug to go into the RX, would this solve my issue?
06-21-2013, 11:36 AM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
It would help, but a BEC would be better. Also, see if turning down your steering end points helps. At full lock, you're running the servo at full power with nowhere to go.
06-21-2013, 11:37 AM | #3 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
It should help the issue, you can also get a bec, that will also fix your problem. -sent from my smarter than me phone |
06-21-2013, 08:22 PM | #4 |
| Re: Timbuk2 wraith question.
Thanks guys. It doesn't do it much so ill try the cap before the bec.
Timbuk2 wraith question. - Similar Threads | ||||
Another Timbuk2 Question... | Freakshow185 | Electronics | 6 | 05-06-2013 10:21 PM |
Help..Novak Timbuk2 Wraith edition | bignose13 | Axial Wraith | 4 | 01-06-2013 12:29 PM |
Novak Timbuk2 Wraith Edition | GravelDuster | Axial Wraith | 8 | 09-01-2012 08:41 AM |
Timbuk2 Wraith Edition Problem? | Team Jeff | Axial Wraith | 7 | 01-18-2012 09:28 AM |
