Thread: What is the factory voltage setting for the cc bec?
Old 07-04-2013, 07:43 PM   #1
Default What is the factory voltage setting for the cc bec?
What is the factory setting(s) of the cc bec?
I would like to purchase a cc bec for a scaler rig, but don't want to buy the castle link, yet, if I don't have to...
Thanks in advance
ScalerFab is offline   Reply With Quote
Old 07-04-2013, 07:52 PM   #2
Default Re: What is the factory voltage setting for the cc bec?
Found the answer...
Their website says 5.1 volts... Darn... Was hoping it was 6...
Old 07-04-2013, 08:17 PM   #3
My lhs programmed mine for me
Wraith913 is offline   Reply With Quote
Old 07-04-2013, 08:24 PM   #4
Pretty sure its 4.8
Sent from my Galaxy Nexus using Tapatalk 2
jdmguy760 is offline   Reply With Quote
Old 07-04-2013, 08:28 PM   #5
Go over to this site...
Holmes Hobbies LLC
At checkout you can select at what voltage you want it set.
KC5H is offline   Reply With Quote
What is the factory voltage setting for the cc bec? - Similar Threads
Quark ProCar 33A factory setting? Tomdigger Electronics 3 02-17-2010 03:35 AM
Need info for best BEC voltage setting. AgentXXX Electronics 6 08-29-2009 05:51 PM
Voltage setting on CC bec - need help! papabash Electronics 6 08-09-2009 05:36 AM
setting output on a bec? Dubs Chops Electronics 2 01-23-2009 12:11 PM
CC BEC setting for HS645MG 4RnrRick Electronics 5 06-06-2008 08:53 AM
