Thread: question on esc
Old 07-30-2013, 06:12 AM   #1
Default question on esc
Traxxas - XL-2.5 ESC with LVD (#3024R) - Overview | traxxas.com
u can get them on ebay for 25/35$$ it has what i need but on motor limit
do i stay between 10/12t or nothing above or under 10/12 little confused
Ohioskills is offline   Reply With Quote
Old 07-30-2013, 06:24 AM   #2
Default Re: question on esc
No those are minimums. You cannot go under those turn counts in motors. You can run higher turns no problem. The lower the turn motor the more power they consume.
jaloos is offline   Reply With Quote
Old 07-30-2013, 06:35 AM   #3
thanks but i just got the XL-5 with LVD
Old 07-30-2013, 02:10 PM   #4
as mentioned above
same thing applies with the XL-5. the motor limit tells you it can handle any number HIGHER than the limit.
If you're using this in a scale rig, you may want to consider higher than 20 turn motors anyway....unless you're just looking for nasty speed. In which case keep in mind the motor limits on that particular ESC - 15t for 540 size motors and 12t for 550 size motors -
redsawacs is offline   Reply With Quote
question on esc - Similar Threads
esc question traxxasemaxxer Electronics 9 10-07-2012 09:55 AM
esc question builder Newbie General 4 10-01-2011 09:37 PM
ESC question martinez34 Electronics 8 02-21-2011 02:46 PM
K.O.H. esc question rckid14 Electronics 4 07-05-2010 03:58 PM
ESC Question SupermanWV Electronics 3 02-16-2005 12:54 PM
