08-10-2013, 02:07 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| important lesson learned today.
i learned what 3s does to a dynamite 15t motor out of TH under the load of a pull off.....for those curious, it flat out smokes the brushes probably wrecked the winding's too. so i am on the hunt for a new motor. thinking about just doing a stock axial 27t but i don't want to lose my wheel speed. currently i am running a creeper trans and a 20tooth pinion. the setup was doing good till i got the bright idea to have a pull off with my dads stock wraith....i lost. i am going to have to sacrifice wheel speed, but i don't want too. here is a question though i see a lot of comments about 35t and 3s, what is recommended? how low of a turn can you run and still maintain decent motor life. i don't comp, just social crawls and small exhibitions |
08-10-2013, 03:18 PM | #2 |
| Re: important lesson learned today.
I ran 35t for my comp truck and have Brood doing a 35t motor for my Wroncho. I'll run 2s and 3s.
08-10-2013, 04:51 PM | #3 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
I run 35t on 3s and have had no problems but it all depends on gearing and stuff as well. If I was you I would look into a good quality motor or Why don't u run a brushless setup? |
08-10-2013, 05:13 PM | #4 |
My son & I run 35T on 3S LiPO's in our 2.2 comp rigs, no issues. Machine wound can be "cheap" but decent, hand wound is a little more cost but usually a better motor. Holmes & Br00d both do good motors. Part of your question is..... what will your ESC support? As 1r3land asked, why not brushless? Will your ESC support that? |
08-10-2013, 05:29 PM | #5 |
I was running brushless and ditched due to several issues I was having. Plus I wanted to be water proof. I just bought a 35t rc4wd to see how a 35t will so for my needs. Cheap testing.
08-10-2013, 05:31 PM | #6 | |
Just switched to waterproof holmes unit, so pretty much anything I want lol. Idont want to go over 3s until I upgrade to CVs in my scx10 axles. | |
08-10-2013, 10:52 PM | #7 |
Pebble Pounder Join Date: Apr 2013 Location: Central PA
I was not brave enough to try 3s in my TH stock, though I have a friend who tried something similar and ended up destroying his motor pretty much. I upgraded to a pretty cheap sensored brushless Turnigy and my LRP esc. I want to change out the esc for something with at least a drag brake, though.
08-11-2013, 10:33 AM | #8 | ||
| Re: important lesson learned today. Quote:
I've used sealed cans, Integy, Venom Fireballs, but the motors I love the feeling of the best are an old Twister Annihilator (9 turn/double, from back in the 80's or 90's), my Holmes Torquemaster Pro 35 turn, but best of all is my Brood Apocalypse S/35 (skewed armature, 35 turns). I also think if you're as much of a wheel-speed junkie as you say, I just don't know that you'll be happy with a 35 turn. Even with as much as I love my 35's on the crawlers, for the trail truck I'm in the middle of, I think I'm either going to save up for a 25 or 30 turn, or I'm going to pull a spare off the shelf (probably the MotorMan, no idea on what it's got in it), and use one of those. But going from a 15 turn to a 35 turn has got something akin to culture shock for you! . | ||
08-11-2013, 01:12 PM | #9 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
Holmes makes a motor for the twin hammers that would probably suit you needs. Not like it can only go in a TW. It has plenty of wheel speed on 3s and is brushed. I personally thought it was an awesome motor and it was pretty cheap. Holmes Hobbies LLC |
08-11-2013, 03:45 PM | #10 |
I am sure it will be culture shock, I am also thinking I should just a rock racer to feed my speed need.
08-12-2013, 01:45 AM | #11 | |
Rock Crawler Join Date: May 2012 Location: Upland
08-12-2013, 08:01 AM | #12 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: important lesson learned today. |
08-12-2013, 11:30 AM | #13 |
08-12-2013, 01:47 PM | #14 |
From experience: Sealed can RTR motors don't last long on 3s, especially under heavy and continual load (going fast). You might get a pack or two out of them depending on how you drive it. A similar wind in a rebuildable style will do you better for longevity. Don't know that I would spend good money on one though. Its kind of a toss up between using and throwing away a cheap sealed can, or spending a few dollars more on a rebuildable can that will last a bit longer before you throw it away. If you pick up a comm lathe you can extend the life of the rebuildable unit by quite a bit. Water + dirt kills comms and brushes, even moreso when you up the voltage. If you want some motors/comms that you can dispose of when they are trashed, I think I've got several in the 15t range. |
08-13-2013, 08:02 AM | #15 |
I might be interested, the only problem is swapping motors in this creeper trans. hate to ditch, it's never let me down expect for issues i have caused ( running the wrong fastener in and trashing a gear). But i also have a TH 2-speed i have been thinking about using.
important lesson learned today. - Similar Threads | ||||
Talk about a hard lesson learned. | crash | Chit Chat | 37 | 09-15-2009 10:57 PM |
lesson learned | MonsterDDT | Tamiya CR-01 | 4 | 12-12-2008 04:38 PM |
English Lesson for Today | wyattburp | Chit Chat | 18 | 11-29-2007 11:22 AM |
