08-17-2013, 10:26 AM | #1 |
| Vintage kyosho Le Mans motor questions... John? Eddie?
The following questions are about these motors: If I understand correctly the 480, 600, etc doesn't identify the size like normal, but identifies how many seconds the motor should run on a 1200mah nicad pack. (I remember racing with those packs... Lol). Is this correct? I know the 600 is a 30t. It seems like it might have potential. How is the aluminum front face attached to the steel can? The end bell looks very minimal/light. Is there any issue with them? Some seem to have plastic end bells while others have a similar looking aluminum end bell. What magnets did these have? Finally a question about the trinity tuned versions of these. Are the magnets different or are these the same motor but wound by big Jim? |
08-17-2013, 11:13 AM | #2 | |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: Vintage kyosho Le Mans motor questions... John? Eddie?
The plate it attached a few ways. Its been forever since I played with one. Some were crimped like a sealed endbell, some glued....some with screws. There was a lot of variations of those motors. The aluminum endbell is not very light at all, especially compared to a plastic unit....plus certain steps had to be taken to insulate the brush hoods. Old ceramic mags of some sorts, back then they didn't really brag about the magnet type..... Trinity versions were tuned, came in handwound versions....same base teardown though. Certainly not done by jim, way before he worked at trinity. Jim did sell a few of the teardowns under his checkpoint label though..... Later EddieO Quote:
08-17-2013, 12:05 PM | #3 | |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Re: Vintage kyosho Le Mans motor questions... John? Eddie? Quote:
Roll pins in some versions | |
08-17-2013, 04:15 PM | #4 |
It seems like it would be a cool can to lathe and stick some decent magnets in.
08-17-2013, 05:20 PM | #5 |
I have a handfull of pinned and screw affixed cans here. Good stock to start from if you wanted a two piece can. It does make magnet installation easier to jig. If you bug sales for loose parts we could set you up with any parts needed and point you to glues. Magnets are best zapped in the can, but we could send them in a junk one so you could slide them in as a pair with constant back iron to keep the mag field together. All in all a lot of work, but if you have the time and resources it's fun to fiddle with. Cleaning out the old can is the hard part. Bake the sucker at 400F+ for 15 minutes or as long as you like. Knock the magnets out and then sand or wire brush out the leftover crap. Degrease with acetone, then glue. Last edited by JohnRobHolmes; 08-17-2013 at 05:22 PM. |
08-17-2013, 05:56 PM | #6 | |
Would I be better off making an endbell that would use checkpoint brushes or would v2 brushes be better? The v2 brushes bounce less, correct? V2 brushes seem like they wouldn't stick out towards the rocks as much either. | |
08-17-2013, 07:58 PM | #7 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Thanks for posting this. It brings back memory of my teenage days with Turbo Optima and le man motor. I had the green 480 and the brown 240. The 240 need to use very small pinion from memory....
08-17-2013, 08:02 PM | #8 |
| Re: Vintage kyosho Le Mans motor questions... John? Eddie? That would make sense (the small pinion) since it was rated to drain a 1200mah in 240 seconds.
08-17-2013, 10:24 PM | #9 |
Both are good brushes, can't really go wrong.
08-19-2013, 07:54 AM | #10 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
wow, thanks for posting this up. i have the 480 gold and always wondered the background on these. e |
08-19-2013, 02:04 PM | #11 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
"If I understand correctly the 480, 600, etc doesn't identify the size like normal, but identifies how many seconds the motor should run on a 1200mah nicad pack. (I remember racing with those packs... Lol). Is this correct?" This is correct. I still use a few 600Es in my slower fun cars like my Lunch Box. I have an instruction sheet which I think lists the windings, I'll scan and post it tonight. |
08-19-2013, 08:06 PM | #12 |
Here's the manual that came with the motors. Page 1: https://picasaweb.google.com/lh/phot...eat=directlink Page 2: https://picasaweb.google.com/lh/phot...eat=directlink |
Vintage kyosho Le Mans motor questions... John? Eddie? - Similar Threads | ||||
vintage kyosho 4runner | vonclod | 2.2 Scale Rigs | 9 | 03-03-2010 09:21 PM |
vintage kyosho truck...... help!!! | charley- | General Crawlers | 27 | 10-13-2006 06:17 PM |
