Thread: Rocket reverse problem
Old 08-31-2013, 07:21 PM   #1
Exclamation Rocket reverse problem
Just wired up my Wraith today.
  • Futaba 4PKS
  • Tekin RS gen2 ESC
  • 2s lipo
  • Tekin pro4 motor
Problem is every time I reverse with more than a slight feather on the trigger the Wraith takes off in reverse at high speed and out of control... I don't know if its the radio or the ESC. I set the ESC up with the HOT WIRE with reverse speed set at 25%...trying to figure this out for the last couple hours, any help would be greatly appreciated.
Cale262 is offline   Reply With Quote
Old 08-31-2013, 08:06 PM   #2
Default Re: Rocket reverse problem
Ok, I don't know why or how but I've got it working correctly... Reset the ESC via HOTWIRE to default settings and then reprogrammed the ESC for the Wraith and all is good in the world again.
Old 08-31-2013, 09:07 PM   #3
Location: Turn the mayflower around.. it will never work
It was Prolly the calibration to the esc.
JokersWild is offline   Reply With Quote
Rocket reverse problem - Similar Threads
AX10 reverse problem. Mr.JayDeeM Axial AX-10 Scorpion 10 10-31-2011 07:24 PM
Reverse problem with the summit durwank Traxxas Crawlers 14 09-18-2011 12:20 AM
Reverse problem calikingcrawler Axial AX-10 Scorpion 3 03-14-2009 04:28 PM
reverse problem mudrinner4ever General Crawlers 2 06-24-2006 12:41 PM
