09-05-2013, 01:18 PM | #1 |
Pebble Pounder Join Date: Oct 2007 Location: Barnesville
| NiMH battery questions ?
Hey guys I got this battery I know I know I need to go lipo but for right now this is what I got to work with. It came with my wraith as a promo. I received my charger yeaterday which is a limax b6-ac I'm new to NiMH and these kind of chargers. I selected NiMH function changed it to auto charge left the peak detection settings default changed the charge rate to 1c I also set the cutoff setting to 3300 mah to not over charge the battery. It wasn't on the charger but maybe 15 min. And it said it was fully charged. I got a run time of about 5 minutes that doesn't seem right to me. I know NiMH have a memory but I dont know much about how it works exactly Trying to figure out if this is a issue with the charger or the battery do I need to do a trickle charge ? sent from old rotary phone using tapatalk |
09-05-2013, 11:39 PM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
If you drive really hard, 3000mah Ivan be gone through in 5 -10 minutes. You might try cycling the battery a few times. Nimh batteries do best once they've gotten a little exercise.
09-06-2013, 12:43 AM | #3 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: NiMH battery questions ?
What ESC are you using? Maybe the Lipo cutoff is activated, so the ESC will "think" this is a 2s lipo and cut off at about 6.8v (3.4v per cell). What is the discharged voltage from battery? Edit: you are using it on the RTR wraith? The AE-2 ESC may have built-in lipo cutoff activated by default. |
09-06-2013, 01:32 AM | #4 |
NiMH does not have a "memory" like NiCD has. As mentioned, most batteries work better after a few full charge/discharge cycles. As to setting an upper limit for capacity (mah) during charge is not really needed in a decent charger which you have. Most chargers will go by "delta peak", or, "peak voltage" (both are the same thing, different term). Was the pack warm when charged? NiMH/NiCD should be warmer than room temp when they are fully charged. As mentioned, it may be an ESC setting. |
09-06-2013, 01:44 AM | #5 |
Sounds to me like a common, run-of-the-mill false peak. NiMhs/NiCads get warmer as they get fully charged. When your charger kicked out after only 15 minutes, was the pack warm at all? When charging, I look for an even temperature in the pack overall. Usually if I find I'm having a hot spot in the pack, I'll assume that cell is on it's way out. . |
NiMH battery questions ? - Similar Threads | ||||
Need NiMh battery help. | kwonchoba | Electronics | 3 | 12-03-2011 07:06 AM |
Best NIMH battery | martinez34 | Electronics | 6 | 01-25-2011 02:40 PM |
Low cg battery plate nimh battery | aej_27 | Axial AX-10 Scorpion | 10 | 01-17-2011 08:44 AM |
NIMH questions/problems | Tacoma747 | Electronics | 6 | 11-25-2007 08:46 AM |
