Thread: CC BEC Signal Wire
Old 10-08-2013, 09:37 AM   #1
Default CC BEC Signal Wire
Got a quick question to throw out there.
When using a CC BEC and wiring it up with a "Y" harness does the signal wire from the BEC need to be taken out of the picture?
Is it used for the programming of the BEC and thus will it cause some issues?
Other NON Castle BEC I have not worried about the signal wire as they are not programmable.
jaloos is offline   Reply With Quote
Old 10-08-2013, 10:40 AM   #2
I've omitted the signal wire out of laziness pretty much. No need to keep unless one is programming it. No issues so far
Meatwad is offline   Reply With Quote
Old 10-08-2013, 10:49 AM   #3
Default Re: CC BEC Signal Wire
Reason i use the Y harness is to keep the end intact for programming purposes and to make it easier to replace servos in the future.
I will just pop the signal wire out of the Y harness end and leave the BEC plug intact. That will isolate the signal wire from the receiver to the BEC and servo so there is no possibility of cross talk in the signal wires. This will allow for easy programming in the event a higher voltage servo is ever installed and the BEC needs programming.
Old 10-08-2013, 11:37 AM   #4
Ah true, in that scenario it's needed so I'd leave it intact.
For my wiring, a mixture of rx and jst plugs keeps things manageable and modular. For instance a Y from the bec to an hv servo and winch. And a Y from the hv servo, jst plug for power from bec and rx plug for signal to rx (signal wire & ground only). Also makes things easy to read at a glance without unnecessary wires.
Old 10-08-2013, 02:10 PM   #5
I keep the plug intact and pull the signal wire out (BEC side) and cover it with heat shrink, same scenario I still can put the plug back together for reprogramming in the future.
rangercat23 is offline   Reply With Quote
Old 10-08-2013, 04:07 PM   #6
Eh I will just yank the signal wire off the Y harness that the BEC will be plugging into. BEC plug will be left intact no wire to un shrink tube and ram back into the plug. Just yank it from the wire harness and program away.
Old 10-08-2013, 07:40 PM   #7
I hear ya, that definitely sounds easier.
CC BEC Signal Wire - Similar Threads
BEC wire Dfl4000 Electronics 3 04-24-2013 12:36 PM
How to wire a exceed rc bec idk Electronics 15 03-30-2012 12:02 PM
whats the best way wire my CC Bec 10 freonman Electronics 0 09-08-2009 09:31 PM
Bec wire question eric113 Electronics 5 09-06-2009 07:27 PM
How to wire a CC BEC? fusebmx13 Axial AX-10 Scorpion 5 04-15-2009 04:29 PM
