10-08-2013, 09:37 AM | #1 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| CC BEC Signal Wire
Got a quick question to throw out there. When using a CC BEC and wiring it up with a "Y" harness does the signal wire from the BEC need to be taken out of the picture? Is it used for the programming of the BEC and thus will it cause some issues? Other NON Castle BEC I have not worried about the signal wire as they are not programmable. |
10-08-2013, 10:40 AM | #2 |
I've omitted the signal wire out of laziness pretty much. No need to keep unless one is programming it. No issues so far
10-08-2013, 10:49 AM | #3 | |
| Re: CC BEC Signal Wire Quote:
I will just pop the signal wire out of the Y harness end and leave the BEC plug intact. That will isolate the signal wire from the receiver to the BEC and servo so there is no possibility of cross talk in the signal wires. This will allow for easy programming in the event a higher voltage servo is ever installed and the BEC needs programming. | |
10-08-2013, 11:37 AM | #4 |
Ah true, in that scenario it's needed so I'd leave it intact. For my wiring, a mixture of rx and jst plugs keeps things manageable and modular. For instance a Y from the bec to an hv servo and winch. And a Y from the hv servo, jst plug for power from bec and rx plug for signal to rx (signal wire & ground only). Also makes things easy to read at a glance without unnecessary wires. |
10-08-2013, 02:10 PM | #5 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
I keep the plug intact and pull the signal wire out (BEC side) and cover it with heat shrink, same scenario I still can put the plug back together for reprogramming in the future.
10-08-2013, 04:07 PM | #6 |
Eh I will just yank the signal wire off the Y harness that the BEC will be plugging into. BEC plug will be left intact no wire to un shrink tube and ram back into the plug. Just yank it from the wire harness and program away.
10-08-2013, 07:40 PM | #7 |
I hear ya, that definitely sounds easier.
CC BEC Signal Wire - Similar Threads | ||||
BEC wire | Dfl4000 | Electronics | 3 | 04-24-2013 12:36 PM |
How to wire a exceed rc bec | idk | Electronics | 15 | 03-30-2012 12:02 PM |
whats the best way wire my CC Bec 10 | freonman | Electronics | 0 | 09-08-2009 09:31 PM |
Bec wire question | eric113 | Electronics | 5 | 09-06-2009 07:27 PM |
How to wire a CC BEC? | fusebmx13 | Axial AX-10 Scorpion | 5 | 04-15-2009 04:29 PM |
