10-09-2013, 12:39 AM | #1 |
Newbie Join Date: Oct 2013 Location: usa
| I need help with my scx10 honcho ax90016
Hi i'm new in this a friend of mine gave me the scx10 honcho brand new and i have an speedpack 5100mah 8.4v 7-cell hump ni-mh battery my problems 1- It goes too fast with a single touch to the remote 2- it moves by itself like it is alive (the tires start moving to the sides and start moving forward or backward) without touching the remote can you guys help me? |
10-09-2013, 12:41 AM | #2 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Re: I need help with my scx10 honcho ax90016
What radio system do you have?
10-09-2013, 12:53 AM | #3 |
radio:2 channel here are the specs Axial Racing - SCX10 - 1/10th scale electric 4WD truck - RTR w/Trail Honcho Body |
10-09-2013, 01:00 AM | #4 |
Rock Stacker Join Date: Sep 2013 Location: sd
my ax10 had the older radio like that, it sucked and my truck was very glitchy. hobbypartz has the flysky gt3b for like 40$, the radio has amazing range and the receiver is TINY I like all the digital settings too! If your new to that stuff watch some YouTube videos on how to set it up.
10-09-2013, 01:01 AM | #5 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
try fresh batteries in the transmitter.
10-09-2013, 01:45 AM | #6 |
ok about the transmiter but what can i do with the car moving by itself even when the transmitter is off
10-09-2013, 02:35 AM | #8 | |
| Re: I need help with my scx10 honcho ax90016 Quote:
older am radios just pick up signals especially when the tx is off. Alot of esc claim "signal loss protection" but that's with like a nicer 2.4gh imo. Or a really nice esc. But the self movement is interference. Make sure the crystal set/frequency set is the same, I have had 2 that were very close and would do something's but lose connection after like 2ft. Another option is to try a different tx/rx if you have one lying around, just to verify where the problem is coming from. | |
10-09-2013, 04:04 AM | #9 |
Quarry Creeper Join Date: Jan 2011 Location: vincennes 2 hours south of indianapolis
No 1 rule turn reciever first before trsnsmitter
10-09-2013, 06:59 AM | #10 |
| Re: I need help with my scx10 honcho ax90016 +1...... TX on, RX/rig on........RX/rig off, TX off. You may want to recalibrate the RX to the ESC to fix the other issue. Eventually, you will want to replace the radio. A hacked GT3B/GT3C is a good way to go. They are newer 2.4ghz radios that can handle up to 8 channels. |
10-09-2013, 09:24 AM | #11 | |
you can buy 5000mah AA rechargeable batteries online for cheap and they run for like 20+ hrs. If you were referring to the battery hack. What hack are you talking about? | |
10-09-2013, 09:39 AM | #12 | |
http://docs.axialracing.com/instruct...structions.pdf Please note that the fail safe setting isn't intended to be a replacement of the proper power on/power off process for the transmitter and receiver. | |
10-09-2013, 10:56 AM | #13 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
The stock AE-2 speed controller is rated to 6 cell batteries, not 7. I know you can run 11v lipo batteries but I have seen 7 cell batteries fry the speed controller. As already mentioned, the receiver may be damaged. If so, it will need to be replaced. You can also attemp a reprogram of the speed control.... http://www.google.com/url?sa=t&rct=j...6VN-oS9tq4zVfw |
10-09-2013, 11:54 AM | #14 | |
Yes, there are a few "mods" which include the steering wheel bearing as well as the "VR mod" that drops the battery load giving a longer runtime on the TX batteries. Check out "OverkillRC" in my sig to find out more. It's a vendor on this forum. | |
I need help with my scx10 honcho ax90016 - Similar Threads | ||||
The difference between the scx10 rubicon and the scx10 honcho | RC_addict1 | Axial SCX-10 | 14 | 01-06-2015 08:52 AM |
New guy, SCX10 Honcho RTR, a few questions about my Honcho | dan188 | Axial SCX-10 | 2 | 10-04-2013 09:43 AM |
Will SCX10 Honcho Kit Parts Fit on Older SCX10? | alexchen86 | 1.9 Scale Rigs | 4 | 12-23-2009 03:56 PM |
