10-13-2013, 11:30 PM | #1 |
Newbie Join Date: Sep 2013 Location: israel
| Hitec 7955 programming
Is it possible to setup the hitec 7955 without the programmer? Maybe, Something like usb cable.... |
10-14-2013, 07:58 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Hitec 7955 programming
Nope. Ya have to have the programmer.... Also some need a seperate power system hooked to programmer.
10-14-2013, 09:06 AM | #3 | |
| Re: HiTec 7955 programming Quote:
+1, no other way that I'm aware of other than adjustments (EPA's & centering trim) on the TX. | |
10-14-2013, 09:16 AM | #4 |
I want to set the length of the movement
10-14-2013, 09:31 AM | #5 |
| Re: Hitec 7955 programming If you want it shorter, use the steering EPA's in your TX. If you want it longer, get a longer servo arm or shorter knuckle arm. Sometimes you can up the EPA's to more than 100% as well. Note: "EPA" = End Point Adjustment. |
Hitec 7955 programming - Similar Threads | ||||
Hitec 7955-TG Servo | losi22 | Electronics | 10 | 09-02-2012 01:40 PM |
hitec hs-7955 | afrofroggy | Electronics | 1 | 01-05-2011 01:03 AM |
hitec 7955 | Mr.Cool | Electronics | 3 | 12-04-2008 05:06 PM |
HITEC 5955 or 7955 | barbaricboye | Newbie General | 14 | 08-23-2008 02:57 PM |
