12-08-2013, 02:04 PM | #1 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| hh 7t cobalt puller and sidewinder problem?????
im trying to run my 7t cobalt puller i just purchased with a sidewinder sct esc and the motor wont run, it will start to turn then stop, if i let of the throttle and grab it again it does the same thing, starts turning then stops. what is possibly my problem?
12-08-2013, 02:16 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: hh 7t cobalt puller and sidewinder problem?????
I believe the sidewinders have a turn limit on how low you can go
12-08-2013, 02:33 PM | #3 |
damn i was thinking that might be the problem, looks like i will have to buy a brxl, sooner then later. i didnt plan to run it on the sidewinder in my rig, just needed to see if the motor worked.
12-08-2013, 02:43 PM | #4 |
Right, check the programming in the castle link it might be set to brushless
12-08-2013, 02:55 PM | #5 |
i checked on that, it didnt say anything about reprogramming for brushed, just how to hook the wires up, i need to get a usb cable so i can use my castle link i just recieved to see if i have to change the programming.
12-08-2013, 02:59 PM | #6 |
you were right it has a turn limit, i finally found it 19t in reversing mode, darn.
12-08-2013, 03:02 PM | #7 |
There is a spot in basics where you can change it, if it's set to brushless it will not work
12-08-2013, 03:04 PM | #8 |
Yeah that sounds right. I've got a 7t puller as well, I run it on a brxl. It's pretty awesome on 3s
12-08-2013, 03:59 PM | #9 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
I've run my 7t and 10t puller on regular sidewinder with 3s with zero issues minus breaking gears.
12-08-2013, 04:18 PM | #10 |
| Re: hh 7t cobalt puller and sidewinder problem????? |
12-08-2013, 04:19 PM | #11 |
hh 7t cobalt puller and sidewinder problem????? - Similar Threads | ||||
Cobalt puller? | chris_snchez | Electronics | 8 | 05-13-2013 05:50 PM |
Major problem with the cobalt puller | ubbb69 | Electronics | 4 | 03-18-2009 08:15 AM |
Cobalt puller 7t?????????? | JPB-rides | Newbie General | 4 | 09-22-2008 09:35 AM |
