12-28-2013, 09:12 PM | #1 |
Rock Stacker Join Date: Feb 2011 Location: NSW, Australia.
| Need help calibrating a hacked GT3C
I hacked my GT3C the other day and according the the instructions from Overkill, step 7 says the steering and throttle need to be calibrated. Step 7 says 'CAL' should come up on the screen. I had it come up once, then disapeared before I could calibrate it. I reflashed the firmware for a second time to see if CAL would come up again, but it didn't. Is there a way to access it from the menu? The menu isn't exactly easy to follow. Another issue I have is the on screen voltage reads 9.3v, but the battery is only a 3.7v. It tests ok with a multimeter. Any suggestions? I contacted Overkill the other day but haven't got a response yet. I'm guessing they aren't opperating over christmas/ new years. Any help would be great. |
12-28-2013, 09:15 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: Need help calibrating a hacked GT3C
Calibration Procedure (you will need a volt meter) To enter menu turn radio on, turn wheel full right then press and hold enter. Its also displays right after you flash a new firmware...from stock firmware With the 1 displayed on your left Hold ST Wheel full left till numbers stop moving, Press enter Let ST Wheel center, once numbers stop changing press enter Turn wheel full right, once numbers stop changing press enter Now turn the enter button till 2 is displayed on your left Hold trigger full throttle, let numbers stabilize press enter Let trigger center, let numbers stabilize press enter push trigger full reverse, let numbers stabilize Press enter now scroll to 4 with a volt meter measure your current battery voltage press enter (while 4 is displayed) Now scroll to the voltage your volt mete read press enter Now press and hold enter till you exit the calibration menu. |
12-30-2013, 03:38 AM | #3 |
Worked a treat. Thanks |
07-23-2014, 05:22 PM | #4 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
Thanks for this. Helped me out.
Need help calibrating a hacked GT3C - Similar Threads | ||||
Where to buy a hacked gt3b or gt3c | chattinfarms | Electronics | 5 | 08-21-2013 11:48 PM |
problem calibrating a tekin rs to a gt3c | m1009cucv | Electronics | 7 | 07-05-2013 02:57 AM |
