01-03-2014, 09:04 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
| Soldering to PCB's
Hello, Does anyone here have experience on soldering heavy gauge wires to PCB’s? For example a 12AWG wire to an ESC board? Because I bought an old BR-XL off the classifieds and the previous owner cut the wires ridiculously short. I know I could probably get away with splicing but I really hate the look of it. If I’m not mistaken, the solder joints on the BR-XL are done using 60/40 leaded solder, which is a bonus since the lead free solder is not fun to work with at all. Any help would be greatly appreciated. Thanks |
01-03-2014, 09:58 PM | #2 |
| Re: Soldering to PCB's
Hot iron plus big tip.
01-03-2014, 10:34 PM | #3 |
Newbie Join Date: May 2009 Location: Las Vegas
Get old wires out, clean of as much old solder as you can. Then depending on size of hole. trim outer wires down do after you tin the wire it will fit threw the hole. Re tin ecs and then mate them. I would always change out for deans 12ga wire when i was racing.
01-03-2014, 11:18 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
use a good soldering station, not a cheapie iron. get it nice and hot, then add solder to the posts your trying to unsolder. Pop the bit of wire out, and I use compressed air to blow all the excess away ( blow it off the board not towards it)
01-04-2014, 09:55 AM | #5 |
Thnaks for the help |
01-04-2014, 11:37 PM | #6 | |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: Soldering to PCB's Quote:
There is a device which suck the molten soldered from the PCB, instead of blow it everywhere.... | |
01-04-2014, 11:50 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Farmington
Solder wick works well too!
Soldering to PCB's - Similar Threads | ||||
Burning through soldering tips? And other soldering questions | losikid | Electronics | 14 | 12-16-2010 10:04 AM |
soldering | rc_man | General Scale Talk | 8 | 08-31-2009 09:49 AM |
need help soldering.......... | bob1961 | Tools, and Procedures | 9 | 11-27-2008 08:56 AM |
What soldering iron for battery soldering? | Flatty | Electronics | 1 | 06-23-2008 07:35 AM |
soldering??? | rockhound | General Crawlers | 12 | 12-10-2004 04:48 PM |
