01-14-2014, 05:30 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| 2 different turn motors on one esc?
Is it ok to run like this? I have a moa with an outcry dual motor esc. As of right now i have 2 35t novak motors but i was thinking about putting a 55t in the rear to make it like an overdrive/underdrive. Im running a servo/micro switch dig on the rear axle. The 35t doesnt lock up strong enough and i sometimes get a little clod stall. I cant go with a smaller pinion in the rear cause the motor is as close as it can get and i dont want to put a bigger one up front.
01-15-2014, 03:41 AM | #2 |
| Re: 2 different turn motors on one esc?
With brushed motors it's no problem!
01-16-2014, 09:30 AM | #3 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
Yeah that should work fine. I've seen xr10 comp guys do it and they said it works perfect.
01-16-2014, 10:11 AM | #4 |
Cool im going for it then. I already have the 55t motor. I think its gonna help out alot
2 different turn motors on one esc? - Similar Threads | ||||
I need a fairly cheap esc that can handle 2 17 turn motors. Any suggestions. | slashbasher | Electronics | 12 | 03-04-2012 03:16 PM |
can a mamba max esc run two 14 turn motors??? | jd267 | Electronics | 9 | 10-19-2010 12:35 AM |
High turn vs. low turn motors for crawlin'.... | Offroader5 | General Crawlers | 13 | 03-16-2007 12:42 PM |
