Thread: -Axial AE-2 esc Suddenly Won't Work-
Old 01-17-2014, 03:59 PM   #1
Default -Axial AE-2 esc Suddenly Won't Work-
Hey guys,
I just tried to turn on my Axial Ae-2 to find that it longer works. Before this, everything worked normally. No water, no over-heating, no smoke, no drops, no crashes, no running in hot weather or cold weather or snow. It was looked after very well. Despite this, when I went to plug in a battery today, it did not make the usual chime or LED flashes, and ceased to work. Batteries work on other Rc's, so that should not be a problem.
In Australia we just had a 40+ degree heat wave, and I thought there might be some correlation, but the ESC gets to that temp anyway, and I was not running in this weather at all.
Is this a frequent problem with AE-2's? Or is it something that I can fix? Any help is appreciated! :P ( I don't have a Castle Link so programming isn't really possible)
Cheers,
OnceWasBooker is offline   Reply With Quote
Old 01-17-2014, 04:39 PM   #2
Default Re: -Axial AE-2 esc Suddenly Won't Work-
If it still has the off ,on switch check that. I've had them just lose contact and then their nothing.
old man 52 is offline   Reply With Quote
Old 01-17-2014, 07:11 PM   #3
I would say to check the switch also.
Kingmeow is offline   Reply With Quote
Old 01-17-2014, 07:23 PM   #4
This seems to be a common problem. I would eliminate the switch by cutting it off, then solder the wires together.
Wacki is offline   Reply With Quote
Old 01-17-2014, 08:13 PM   #5
Cut of the switch and it works again. That was the last place I expected the problem to be!
Cheers for your help guys!
Old 01-17-2014, 08:16 PM   #6
Glad we could help out.
-Axial AE-2 esc Suddenly Won't Work- - Similar Threads
axial ae2 esc 3s does it really work? longterm ? cuttyman Electronics 30 05-04-2016 05:21 AM
1990 jeep comanche, horn suddenly stoped working? general lee Chit Chat 8 12-07-2012 01:37 AM
Can any ESC work as a Dual Motor ESC? MRCCRAWLER1.9 Electronics 17 08-17-2010 04:10 PM
lipo suddenly went dead tdodm Electronics 5 06-18-2010 07:12 PM
will this esc work? badtodabone General Crawlers 1 09-11-2004 07:53 PM
