01-19-2014, 09:10 AM | #1 |
Rock Stacker Join Date: Sep 2011 Location: Hartlepool
| Holmes ESC set up
Hi guys, I have the BR-XL and castle link. I usually run 2s 3000 but I'm thinking about picking up a some 3s batteries and give them a try. My question is would I need to purchase the field programmer in order to change the low voltage cut off? Or does the low voltage cut of work completely different and go by voltage per cell? If this has been asked before just link me straight to the thread, I did use the search but couldn't find what i was looking for. Cheers Andy |
01-19-2014, 09:14 AM | #2 |
Rock Stacker Join Date: Sep 2013 Location: Sandy
| Re: Holmes ESC set up
set it to auto lipo (default setting i believe) and u can run 2s-6s
01-19-2014, 09:28 AM | #3 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
It should already be programmed for lipo use...Maybe call or email HH and make sure just to be safe.
01-19-2014, 09:44 AM | #4 | |
| Re: Holmes ESC set up Quote:
This is because I'm looking at getting a 3cell to try. Last edited by Andyking; 01-19-2014 at 09:47 AM. | |
01-19-2014, 10:01 AM | #5 | |
With auto-lipo you can get it confused by putting it a discharged 3S battery which gets close to a charged 2S battery. Unless there has been a recent change, the field programmer only works with the BR-XL when connected to a computer just like the Castle Link | |
01-19-2014, 10:11 AM | #6 | |
I still suggest talking with HH and see what they tell you...Its very little effort to be on the safe side. Some ESC,s have an auto detect with voltage but I don't know for the HH esc...maybe it has to be set manually for more than 7.4v maybe it doesn't. That's why I say talk to them about it. Last edited by 6sharky9; 01-19-2014 at 10:14 AM. | |
01-19-2014, 10:24 AM | #7 |
| Re: Holmes ESC set up |
01-19-2014, 10:32 AM | #8 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
As long as you haven't set the Voltage Cutoff setting to say 2s or 3s you will be able to switch between the two batteries types. The BRXL has the capability (providing the LVC is set to auto detect) to switch on the go. No need to manually change anything. I would plug your ESC up to the castle link and double check to see if the voltage cutoff is set to auto detect. |
01-19-2014, 11:11 AM | #9 |
As was said, just connect a fully charged lipo and make sure the number of beeps match the cell count of your lipo... done.
01-19-2014, 12:39 PM | #10 |
Cheers for the help guys. I was at work when i sent this. Checked just now and its all set up for auto-detect. I'm gonna order a 3 cell battery to give that a try, see how it fairs against the 2 cell
Holmes ESC set up - Similar Threads | ||||
MOA moto set up. Tekin vs Holmes hobbies | mudd_slinger | Electronics | 7 | 09-30-2013 09:54 AM |
