02-20-2014, 09:32 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| Mmp/tekin help
I recently put a mamba max pro and a tekin 13.5t brushless motor in my wraith and it is giving me some issues . I think it's in the settings on the esc . If it's setting still when you has it it just sets there for about 5-8 sec then it goes but if it is rolling then sometimes it will go and sometimes it will pause for a couple of sec. |
02-21-2014, 05:37 PM | #2 |
Newbie Join Date: Jul 2009 Location: Reno
| Re: Mmp/tekin help
If you have the castle link, use the program to reset to defaults. If that works you can then go in and change the settings to what you want. If no castle link, try setting it up again.
02-21-2014, 06:57 PM | #3 |
| Re: Mmp/tekin help
Yes I did use a castle link to set it up but I'm thinking I've got something setup wrong I was hoping someone that was running the same setup could pm me what settings they are running
02-21-2014, 08:11 PM | #4 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Mmp/tekin help
If it only happens when you pull full throttle, then you might be drawing too many amps from your battery and browning out the reciever and esc. It sounds like the same problem I have heard a few times recently.
02-21-2014, 08:55 PM | #5 |
| Re: Mmp/tekin help |
02-22-2014, 01:53 AM | #6 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| Re: Mmp/tekin help
What battery are you using?
Mmp/tekin help - Similar Threads | ||||
tekin rs or mmp | m1009cucv | Electronics | 28 | 07-13-2014 12:24 PM |
MMP/tekin setup | seaturtle | Axial Wraith | 9 | 01-17-2013 03:12 PM |
MMP/Tekin 13.5 | JustinM | Electronics | 36 | 10-29-2012 05:55 PM |
