02-23-2014, 08:42 PM | #1 |
Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
| 5mm LEDs- Wide or narrow angle?
I am going to be wiring up some LEDs to put in the stock light buckets in my new wraith. Does anyone know if it really matters if you use wide (120 degrees I believe) or narrow (40 degrees) LEDs? I don't really expect it to throw much light, even with the narrow LEDs. SO I am thinking go with the wides to make sure I light up the whole light bucket. What do you guys think? |
02-23-2014, 08:45 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: northern
You might be surprised with how much lights the LEDs actually give off. I'd go wide though personally just so you can see more of your surrounding if you decide to take a little nighttime run Sent from my iPhone using Tapatalk |
02-23-2014, 08:46 PM | #3 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
| Re: 5mm LEDs- Wide or narrow angle?
Some of the narrow LEDs (at Radio Shack for example) are a lot less than 40 degrees, which I think are too narrow. Anything in the ranges you listed would be fine IMO. I think the more important part is how bright they are (more lumens = brighter).
02-23-2014, 08:46 PM | #4 |
| 5mm LEDs- Wide or narrow angle? thats my rig 7 total lights 2 headlights and a 5 light, light bar in a completely pitch black basement Sent from my iPhone using Tapatalk |
02-23-2014, 08:50 PM | #5 |
I would recommend narrow if you are actually looking for light. the wide don't project light very far at all and will seem "dim" but great for projects you just want the look of lights on from any angle, but not actually looking to light up the area in front of you. most all LEDs you buy are narrow. typically the wide have a flat or cone concave end on them. the narrow have the standard round end. or best yet, buy both, LEDs are so cheap. wire them up and do a side by side comparison and decide whats best for you. |
02-23-2014, 08:59 PM | #6 |
Newbie Join Date: May 2013 Location: Vancouver
I've seen my best results running (Narrow) (Wide) (Wide) (Narrow) for headlights.
02-24-2014, 09:20 PM | #7 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| Re: 5mm LEDs- Wide or narrow angle? |
5mm LEDs- Wide or narrow angle? - Similar Threads | ||||
Narrow Axle Options w/Lots of Steering Angle | Tommy R | General Scale Talk | 65 | 04-16-2013 07:44 PM |
Should I go wide or narrow? | Mighty Mouse | Tires and Wheels | 21 | 03-31-2007 04:10 PM |
