03-03-2014, 06:06 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Fxr throttle jerky
Fxr Axial 27t 3s Gt3b hacked and used for years with no issues on mmp Throttle was smooth as heck in fwd but rev was an on/off switch right to what could be "walking speed". After the initial bump throttle could be backed off to a creep, but had no power in any bind (against a shoe). Turned down rev strength on esc and it affected fwd motion not rev. I reversed channels and motor leads. Now rev can creep off of stop and is at a lower power (done with esc buttons) but Fwd is still jumpy. I messed with the expos on my radio and they don't seem to affect it at all... Ideas? |
03-04-2014, 06:40 AM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Fxr throttle jerky
make sure your anti braking system is off on your TX, I had the same problem as your describing
03-04-2014, 06:59 AM | #3 |
Newbie Join Date: Feb 2014 Location: Detroit
I had to reset all my settings on my controller and do the radio calibration to get it to work correctly. Also make sure your capacitor is soldered on correctly.
03-04-2014, 08:07 PM | #4 |
I made the throttle neutral band on my tx wider.. Seemed to have helped A LITTLE.. |
03-05-2014, 11:04 PM | #5 |
Pebble Pounder Join Date: Dec 2013 Location: Burbank
You have external BEC?
03-06-2014, 10:40 AM | #6 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Which way do the LEDs climb when you apply throttle? Switching the motor leads and reversing channels will screw up the signals the FXR is looking for. Run your throttle channel on normal, do a recalibration, set the throttle minimum to 0 and only swap the motor leads if it's running in reverse.
03-06-2014, 03:18 PM | #7 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I've got a similar problem with my FXR. Starts with a jerk and afterwards I can let the trottle go a bit and move slower. Seems to lack speed compared to other cars. After some troubleshooting today, I realised it goes faster in reverse than forward. Reeset settings, recalibrated and so on. As I read this topic I realised that I've forgotten to check if the anti braking is off. Will try that tomorrow Tekin Support want me to upgrade software on esc, as the earlier versions acted a little jerky. Strange thing with mine is that the new Tekin 35t motor smells burnt, but it's not hot at all. Barely beginning to feel warm... |
03-06-2014, 05:02 PM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
I also had a touchy reverse when I switched an fxr to a different vehicle. I made sure fwd and reverse endpoints were 150% on my dx3r and then reset the esc epa's. Now it is nice and smooth |
03-07-2014, 04:00 PM | #9 |
Make sure the LEDs are climbing from right to left when you're on throttle. Sounds like it may be calibrated backwards, or you are using the throttle reverse switch on the TX. The FXR looks for a specific signal for fwd/neutrall/reverse. Also make sure you are updated to the latest firmware version. |
03-09-2014, 01:21 AM | #10 |
Hooked up a Castle Sidewinder 3 and everything functions very smooth as intended without changes on radiosettings. So in my case it's an issue with the FXR for sure.
Fxr throttle jerky - Similar Threads | ||||
tekin FXR adjustable Throttle profiles | elliot330 | Electronics | 16 | 06-26-2015 12:06 PM |
FXR Throttle profile | OKJeepin | Electronics | 12 | 05-31-2012 10:17 AM |
Twitching throttle on fxr | rocknut36 | Electronics | 6 | 04-21-2010 10:38 PM |
FXR Throttle Curve Instructions | RCbasher | Electronics | 9 | 07-25-2008 12:48 PM |
