03-10-2014, 05:09 PM | #1 |
Newbie Join Date: Mar 2014 Location: medford
| wire install on hh trail master 3100 brushless
Just got my motor in the mail and I need to hook up wires. Any tips in the best way
03-10-2014, 05:23 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: OC
| Re: wire install on hh trail master 3100 brushless
Use a soldering iron....lighters won't cut it.
03-10-2014, 05:28 PM | #3 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
This worked for me I just went off the a b c wire colors on my mmp esc |
03-10-2014, 05:44 PM | #4 |
Seems easy enough. How do u like that set up I'll have pretty much the same in my wraith for pretty much bashing. Hope its what I'm looking for
03-10-2014, 06:02 PM | #5 |
Haven't been able to take it out trailing yet buy it does seem nice and smooth if setup right . Just make sure u have the sensor wire in good, make sure its geared low enough, and make sure you have enough voltage in your receiver(I had glitching when I had just my mmp esc plugged into my receiver but I'm running a hv hitec servo and a heyok 4a winch controller with a rc4wd in the rear and a kms 220oz winch up front and as soon as I put my bec in the cogging when away) Also by the way even though the box say 2s it can run 3s. That's what I'm running and a couple other people are running 3s also. Check out winnerone23 build wanting a winner xj build he is running it on 3s in his Cherokee and he has a link on his thread showing how the motor runs Also I would suggest switching to 32p gears and some people running this motor shred 48p spur gears I haven't gone to pick up my 32p gears that I ordered from my lhs yet |
03-10-2014, 06:25 PM | #6 |
I put chains on the wraith and bout half a battery later I chewed up my stock servo. I got a hitech 7950th I believe ordered wasn't sure what to get so hope it works. Are u running an external bec than to keep the volts up
03-10-2014, 06:30 PM | #7 |
Yeah I run a hitec 7954sh and I'm running a mmp esc with the hh motor and I run a castle bec set @ 7.4v
wire install on hh trail master 3100 brushless - Similar Threads | ||||
HH Trail Master Sport getting hot | cox308 | Electronics | 18 | 09-13-2013 09:52 PM |
Motor install, connectors or hard wire ? | xCoolHandLukex | Electronics | 7 | 10-16-2012 06:53 AM |
can i use a Trail Master axels? | mr_svensson | Newbie General | 2 | 01-26-2006 07:21 PM |
Tamiya Trail Master | DirkDigler | General Crawlers | 4 | 11-11-2004 10:19 PM |
tamiya trail master | iwantoffroad | General Crawlers | 20 | 10-19-2004 06:18 PM |
