Thread: Could use some help with CC BEC install
Old 03-20-2014, 09:54 AM   #1
Default Could use some help with CC BEC install
I was not able to get the CC BEC to work with the futaba receiver.
Here's what I have - From battery > MMP ESC & CC BEC > ESC into Ch2 receiver.
CC BEC with extension (red wire cut) into CH1.
Hitec 7955TG into CH3?
Receiver doe snot power ON.
Do I have this backwards?
I can't find a wire diagram that shows a Futaba RS and a CC BEC setup. I am new to BEC's.
Markeje is offline   Reply With Quote
Old 03-20-2014, 09:59 AM   #2
Default Re: Could use some help with CC BEC install
OK - I was way off. I didn't plug the BEC into the power port of the receiver :(
Here's a question..
I have the CC programmable card for my ESC's. Can I program the CC BEC with this also?
Old 03-20-2014, 10:39 AM   #3
Here's a question..
If you have the Field Link for Air then it can program the CC BEC. If you have the Field Link for Car then no, it can not.
k7zpj is offline   Reply With Quote
Old 03-20-2014, 03:01 PM   #4
Ah dang. Ok. Thanks.
Sent from my SCH-I545 using Tapatalk
Old 03-20-2014, 08:08 PM   #5
Can I ask why you have the BEC plugged in with the red wire cut? With it being plugged in that way your effectively not using it and using the mmp internal BEC instead.
If it was me I would purchase a y harness. Plug the BEC into one half if the y and the servo into the other . Make sure polarities are matching, then cut the red and black from the plug that goes to the receiver and just plug in the signal wire to control the servo . Let the internal BEC power the receiver and you should be good.
Does that make any sense?
Or at least worst case to utilize the castle BEC you will need to get an extension with the red wire and pull the I've out if your mmp plug.
Good luck
tgh117 is offline   Reply With Quote
Old 03-20-2014, 11:44 PM   #6
Proverbial threadkiller
Trubble's Avatar
Shouldn't your servo have gone in CH1 ?
And, yes, if you've cut the red wire between your BEC and the receiver, you've effectively disconnected the BEC.
Although ........ you didn't mention cutting/pulling any wires on the ESC's plug, I wonder why that thing didn't power up the receiver.
Something(s) in your description doesn't sound right at all. Take some time, look over your setup again, and try to more accurately describe where you've got things.
Trubble is offline   Reply With Quote
Old 03-21-2014, 04:45 AM   #7
I was trying to follow VPS evol video on YouTube. And ya i didn't write the original post quite right. I do have a Y connection to use and I'll try to just do what tgh117 said. Thanks guys. I'll let you know how it goes.
Old 03-21-2014, 08:11 AM   #8
Trubble's Avatar
.......... I'll try to just do what tgh117 said.
Alright, cool. Go that route and let us know what you get done.
Kinda wished you woulda put up a link, but I'll go look for that vid after work.
Old 03-21-2014, 08:33 AM   #9
CC has a PDF that shows how it must be wired. CC BEC Ribbon cable goes into the Bind/Battery port on the receiver. The ribbon cable from the ESC must have the red wire pulled out or cut (I would pull it if it was mine...just lift the plastic prong in the pin housing and slip it out and heat shrink it). The the red and black wires go to the battery. You can solder them to the power plug or use a Y cable.
Here's the CC PDF link http://www.castlecreations.com/suppo...user_guide.pdf
And here's the pic
MountainStorm is offline   Reply With Quote
Could use some help with CC BEC install - Similar Threads
Bec install! Reaxion911 Micro Scale Rigs 11 04-13-2014 11:52 AM
BEC Install markmc90 Axial Wraith 3 03-31-2013 03:08 AM
Bec Install lurchy Electronics 8 01-02-2013 04:48 AM
How to install a BEC in a RS10?? Big Pitt Redcat Crawlers 15 12-12-2010 08:52 AM
Bec install zignzag Electronics 11 11-13-2010 08:32 PM
