Thread: new servo....now its tilts full right on throttle??
Old 03-30-2014, 03:58 PM   #1
Default new servo....now its tilts full right on throttle??
why is it the steering tilts full right while i hit the throttle??
ive never crossed this problem before??
MMP ESC
CC BEC @ 6v directly to the servo (signal to Rx only)
HiTec hs645mg servo
help appreciated!!!
SwampDawg is offline   Reply With Quote
Old 03-30-2014, 05:49 PM   #2
Default Re: new servo....now its tilts full right on throttle??
Off the top of my head I'd say it's plugged into the wrong spot, double check the connections? If they are in the correct spots start looking at the receiver.
Sevastra is offline   Reply With Quote
Old 03-30-2014, 05:54 PM   #3
Suck it up!
Duuuuuuuude's Avatar
1 to turn, 2 to burn.
Duuuuuuuude is offline   Reply With Quote
Old 03-30-2014, 07:08 PM   #4
I've found that tying in a ground to the rx along with the signal wire helps eleviate this problem.
rhett314 is offline   Reply With Quote
Old 03-30-2014, 08:26 PM   #5
last two comments have me lost?
1 to turn, 2 to burn?
and by a ground....you mean wire the signal itself to the _____ ?
also, checked the connections and it still persists?
Old 03-30-2014, 08:41 PM   #6
I mean add the ground back into the rx next to the signal wire. Tied into the ground that is going to the servo.
I wire mine like this diagram post #119. Since doing it this way I have not had the problem you are describing.
Definitive wiring diagrams for BECs Rx Servos Motors etc.
Old 03-30-2014, 09:28 PM   #7
Suck it up!
Channel 1 to turn the rubber (steering), channel 2 to burn the rubber (ESC)...
Old 03-30-2014, 10:36 PM   #8
okay, i know what channels to put things into,thanks...that never changed from my last servo.
as for the diagram...ill give it a shot but honestly dont see it changing it? we will see!
Old 03-31-2014, 05:00 AM   #9
Is all you did was change a servo? Are you sure you didn't inadvertently turn on any channel mixing on your transmitter? sometimes rebinding helps. I was having a similar problem where when I adjusted the steering trim it would engage the throttle... After a fresh binding and calibration it went away. Just my 2 cents
tomvaillencourt is offline   Reply With Quote
Old 03-31-2014, 08:58 AM   #10
this is on my kids wraith which uses analog Tx/Rx, so binding wont assist.
this is frustrating! im thinking this new hitec is a dud?
standing still, it steers fine!
Drive forward and the steering tilts full right.
Turn and hold the steering full left (truck stationary) and hit throttle it still tilts full right?
fuuuuu.....
Old 03-31-2014, 09:54 AM   #11
Where are the servo wires ran? With analog if the wires are ran near the motor or motor wires it can interfere with the signal.
Old 03-31-2014, 09:59 AM   #12
opposite side of the motor along chassis, but last servo ran just fine?
wierdest crap ive seen!! lol
Old 03-31-2014, 10:41 AM   #13
well...
just wired in a ground from BEC to Rx and the servo still goes effing crazy?? WTF??
Old 03-31-2014, 10:51 AM   #14
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Remove your BEC and check. Backfeeding BEC's can cause wacky stuff.
Harley is offline   Reply With Quote
Old 03-31-2014, 02:24 PM   #15
ill have to give the BEC a try cuz nothing makes sense here??
how it worked just fine with his last servo, although it was a standard type?
now going to an entry level servo like this hs645mg, which will be more then enough for his driving style.
Old 03-31-2014, 02:55 PM   #16
Just curious but what kind of controller you are using? I had the exact same issue with another servo and a axial controller and also had it with a losi controller. I swapped to my futaba controller and it went away. It was the strangest thing I have seen especially since the stock servo didn't do it but it did and it didn't matter if I used the bec or not. It about drove me nuts till I tried the other controller for kicks and just left it at that after.
craddock35 is offline   Reply With Quote
Old 03-31-2014, 03:08 PM   #17
HPI TF-4 Tx/Rx for now...
when i get some $$$ together, id love to get both my kids a new 2.4ghz system.
This analog crap is a heap! lol
but its what i had kickin around when i built these rigs.
Old 04-01-2014, 02:35 AM   #18
after work i came home to rewire this rig....
1am and its now wired without a BEC and still the damn servo goes stupid on me?
(Both ESC CH2 and servo CH1 directed to Rx)
im thinking its this analog Tx/Rx causing this crap! ugh!
now ill have to find a 2.4ghz system for this one...
Old 04-01-2014, 02:45 AM   #19
Just watch what system you get. The 2 I have had issues with doing that were both 2.4ghz systems but both were cheap stocker stuff.
Old 04-01-2014, 06:26 AM   #20
on a good note:
i have a spare BEC. lmao!
but how am i to know of what radio to get without spending a fortune on several sets?
new servo....now its tilts full right on throttle?? - Similar Threads
Servo sometimes veers to the left when under full constant throttle BadRockNoCookie Electronics 23 06-08-2012 12:57 PM
servo stops working at full throttle mjderstine Electronics 10 03-21-2012 07:12 AM
Full throttle!!! Help!!!! Scx10 crawler Electronics 10 04-06-2011 04:41 AM
Glitch - str servo turns to right when throttle at full speed? sweli Electronics 2 09-06-2010 12:42 PM
dig servo jumps at full throttle? TWISTEDBYDESIGN Electronics 1 01-12-2009 10:09 PM
