04-28-2014, 05:17 PM | #1 |
Quarry Creeper Join Date: Apr 2014 Location: USA
| 1St time wiring motor question
Hey Guys, I ordered a Hobbywing 3656SD sensored brushless motor for my Wraith. It'll be run by a MMP. I should just solder the 3 wires onto the motor correct? Any reason to use connectors and if so which ones? Order doesn't matter right because I can swap at the ESC? The only other install I did was the SCT sidewinder and it came with the 3400KV motor all prewired except power. |
04-29-2014, 11:33 AM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: 1St time wiring motor question
Yes you need to solder some motor leads onto the motor. Should either come with your ESC or your motor. If not, any LHS or online shop will have them.
04-29-2014, 12:12 PM | #3 |
Running sensored the wires MUST be wired a-a b-b c-c. I solder the mamba max pro wires directly to the motor tabs. No reason for connectors.
04-29-2014, 12:44 PM | #4 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
yep! solder wire onto the A-B-C tabs off the motor. i do however put 4.5mm goldplated connectors between the motor and ESC just in case i need to swap a motor from time to time without having the hassle of re-soldering later on. |
04-29-2014, 03:14 PM | #5 |
Thanks guys. So I am assuming the motor will have the tabs A-B-C, labeled? For that matter, does the ESC? Hm, never looked at this so I'll have to look at the ESC and instructions when I get home. My old setup the order didn't matter and if it was reversed they just said reverse any two wires. The ESC came with connectors on the ESC side so I will be able to swap out the motor or ESC with the quick disconnect if need be .
04-29-2014, 03:46 PM | #6 | |
| Re: 1St time wiring motor question Quote:
1St time wiring motor question - Similar Threads | ||||
1st time building kit wraith question | chapter | Axial Wraith | 8 | 12-28-2011 12:21 PM |
motor wiring question | slashbasher | Electronics | 4 | 08-04-2010 11:22 AM |
Question about motor wiring | Sneff | Newbie General | 3 | 02-08-2007 07:11 PM |
Motor and wiring question..... | smashn | General Crawlers | 5 | 06-06-2006 01:31 PM |
crawling, 1st time driving, 1st time video | ratmloud | Videos! | 10 | 12-01-2004 09:33 PM |
