Thread: Is my esc overheating?
Old 05-22-2014, 05:07 PM   #1
Default Is my esc overheating?
Ok I wanna just ask this question before I pull everything apart. I have a Mamba Max Pro and a Pro 4 4000 in my Wreckluse running Zippy 3s 45c batteries. After running for a bit it just stops with no throttle response at all. I have remover my fan as it wouldn't fit in my electronics box that is sealed tight to be waterproof. I think it is overheating and thats my problem, correct me if I am wrong. I need to pull it out of the box reinstall the fan and leave it out of the box is my assumption. Please lemme know what you think.
Sent from my Galaxy SIII
scoutdawg is offline   Reply With Quote
Old 05-22-2014, 06:11 PM   #2
Default Re: Is my esc overheating?
Overheating would be my guess with the 3s and 4000kv depending on your gearing too but I'm sure there is a pretty good load on the motor and esc and it being in a box with no air to breath it will defiantly heat up
geislerj3 is offline   Reply With Quote
Is my esc overheating? - Similar Threads
overheating esc jacarter87413 Electronics 8 08-28-2013 11:09 PM
esc overheating problems. K4G3 Newbie General 4 02-21-2013 11:42 AM
Smoke/Overheating from ESC SinCity Axial SCX-10 6 06-14-2010 07:09 AM
ESC issue overheating Flatty Electronics 14 07-11-2008 10:15 PM
waterproof an esc without overheating it? slobin3d Electronics 11 06-16-2006 09:38 AM
