11-06-2014, 05:15 PM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: Hood river
| KV rating?
Hi there, Confused on KV rating. I am getting a new motor for my Wraith and these are the same motor with different KV. I want more torque not speed. Which of these two motors should I get? Thanks! 21.5T Sensored |
11-06-2014, 05:24 PM | #2 |
| Re: KV rating?
Lower kv typically means more torque as long as you are comparing apples to apples.
11-06-2014, 05:28 PM | #3 |
| Re: KV rating?
Thanks! Much appreciated....
11-06-2014, 05:33 PM | #4 |
| Re: KV rating?
The slower one has a larger rotor. 21.5t is pretty dang slow and weak. If you want torque a 13.5 on 3s is the sweet spot. Any faster and voltage drop in wires dominates, any slower and motor resistance prevents preak torque without running higher voltage. But if you don't want speed, 21.5 it is. Get the slower one. It will produce more torque since both are 21.5t. |
11-07-2014, 12:29 AM | #5 |
| Re: KV rating?
As noticed these motors are the same armature with different rotors. They will produce the same power and give you the same torque and speed on the wheels given a gearing matching the difference in Kv. You'll probably need to run them on 3S to get a decent upper top speed. |
11-10-2014, 01:12 AM | #6 |
Pebble Pounder Join Date: Sep 2014 Location: USA
| Re: KV rating?
which brand motor do you use?
11-14-2014, 10:00 AM | #7 |
| Re: KV rating?
I had a sensored Tekin 17.5 turn but I put it in my Twin Hammer
KV rating? - Similar Threads | ||||
C rating of a battery | david37370 | Newbie General | 16 | 02-10-2013 10:01 AM |
what c rating | pugs2300 | Losi Mini-Rock Crawler | 10 | 01-08-2012 08:42 AM |
li-po s rating | rybredd | Newbie General | 2 | 03-21-2011 08:05 AM |
The KV rating of a 13.5........ | Scattman | Electronics | 7 | 05-17-2010 04:25 PM |
Feedback Rating | scrooloose | Comments, Suggestions, and Help | 0 | 09-20-2007 06:50 AM |
