02-26-2015, 07:27 PM | #1 |
Newbie Join Date: Feb 2012 Location: Ramona, Kali.
| Output voltage on AE5 ESC
Is the voltage output to steering & aux outputs the same as battery input voltage or is it regulated lower?
02-26-2015, 07:30 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
| Re: Output voltage on AE5 ESC
ae5 internal bec is 5v i believe
02-28-2015, 02:03 PM | #3 |
Yes, it is 5v. I had to disassemble Wraith to connect LEDs & measured it. Anyone know current capacity?
02-28-2015, 02:20 PM | #4 |
Maybe 1 or 2 amps I would guess. If you are putting big loads on it, I would install a cc bec
02-28-2015, 02:59 PM | #5 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Spec sheet says 2A peak.
02-28-2015, 04:09 PM | #6 |
Newbie Join Date: Nov 2014 Location: Australia
Wow I didn't realise it was that low. Even with the Holmes hobbies waterproof brxl at 6v 5amps I'm still running a cc bec.
02-28-2015, 06:28 PM | #7 |
If you run a cc bec it doesn't really matter what the internal is, as its no longer being used.
02-28-2015, 06:55 PM | #8 |
Wow am I a dumb-ass. I meant voltage output of the AR-3 receiver! DOH! Sorry for the cornfusion... I did measure the voltage output of the receiver is 5V. No idea what the current limit is & Axials spec sheet (for the xmitter) has no info. I imagine I need a BEC to take advantage of the HS-7950TH Servo I put in it... |
02-28-2015, 07:16 PM | #9 |
The AR-3 does no voltage regulation at all. Whatever you put in, you get out minus a little bit of line/component loss. I would definitely use an external BEC with the 7950 servo. |
Output voltage on AE5 ESC - Similar Threads | ||||
Voltage output. | philg | Losi Mini-Rock Crawler | 8 | 09-20-2012 03:41 PM |
low output voltage???? | mudn_1 | Electronics | 4 | 11-29-2010 10:52 AM |
CC BEC voltage output | ScaleReady | Newbie General | 4 | 04-20-2010 05:44 PM |
ESC voltage output? | benroe ax10 | Electronics | 3 | 01-16-2009 03:15 PM |
