03-03-2015, 06:10 PM | #1 |
Rock Crawler Join Date: Apr 2011 Location: Sonoma County
| Mamba Max Pro with non-sensored brushless getting little power in reverse
I think my settings are all correct. It's mostly default. I've tried 'with reverse' and 'crawler reverse'. I have an external bec and yes the power wire is disconnected. Any ideas? The ESC is in my Yeti build which is in my signature. Thanks! |
03-03-2015, 06:44 PM | #2 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Re: Mamba Max Pro with non-sensored brushless getting little power in reverse
set your reverse power to 100%
03-03-2015, 08:52 PM | #3 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
| Re: Mamba Max Pro with non-sensored brushless getting little power in reverse Yep. Second that....obviously. It's set to 50% *edit - probably feels like you have virtually zero braking too since it's set to 50% of 10% Last edited by GodSpeed999; 03-03-2015 at 08:57 PM. |
03-03-2015, 10:52 PM | #4 |
I have tried 100% brake also. It seems about as weak. I can push full reverse and still stop and push the truck forward with my hand. Could it be something about using 'smart sense' with a sensorless motor? There is no setting for just sensorless... Here are the settings now. |
03-04-2015, 12:05 AM | #5 |
SMART is the setting to use for BL motors without sensor, so that's correct. You've now also disabled brakes entirely! Drag brake should be at about 100% and Brake amount maximized! |
03-04-2015, 12:26 AM | #6 |
Well I'm racing it around a track mostly right now so I don't want it to break when I let off the gas.
03-04-2015, 06:50 AM | #7 | |
| Re: Mamba Max Pro with non-sensored brushless getting little power in reverse Quote:
Put the Brake Amount to 100% to eliminate that weird variable and then maybe try 10% Drag Brake. It still won't be much at all, but it won't be free-wheeling around when you let off the throttle. And you're on a track and using Crawler Reverse mode with no brakes so I imagine that when you try to use brakes with your trigger finger, you're ending up jamming it into reverse. That will break things a lot faster than a heavier drag brake. Off-throttle front flips don't start until about 100% of 100% or higher. | |
03-06-2015, 11:12 PM | #8 |
Omg it was end point adjustment all along. I'm sorry Internet. This hacked flysky is no joke. |
03-07-2015, 12:07 AM | #9 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Mamba Max Pro with non-sensored brushless getting little power in reverse |
Mamba Max Pro with non-sensored brushless getting little power in reverse - Similar Threads | ||||
running sensored on mamba max pro | c0bra | Electronics | 8 | 07-23-2013 12:41 PM |
Mamba Max Pro Vs HobbyWing 120a sensored Esc | EvanSouders | Electronics | 5 | 09-06-2012 12:56 PM |
