03-18-2015, 10:32 AM | #1 |
Newbie Join Date: Jan 2015 Location: Trondheim, Norway
| 3Racing winch problem
Hello! I recently installed the LockedUpRC Commando - High Performance Motor in my 3Racing winch. I'm using a HeyOK 2pos winch controller, and a Traxxas tqi 4ch tx. The winch works fine with no load, but with a bit of weight on the line (maybe about 1kg), the motor kind of stalls. It sounds like it's still running, but it isn't. The video explains it best, I think: https://youtu.be/ufUzOLdWh1g What's going on? Any input is appreciated! |
03-18-2015, 11:39 AM | #2 |
Newbie Join Date: Mar 2015 Location: Austria
| Re: 3Racing winch problem
Hi. Could it be a kind of overcurrent protection like a BEC or ESC offers? Some have only 1A which could be too less. Your high performance motor seems to draw more current.
03-18-2015, 11:58 AM | #3 |
I don't think so, as it's a Castle 10A BEC set at 6V, running off of a 2s LiPo. It powers my Savox 1210sg just fine. If you listen in the video, the motor still makes a sound as if it's running, while the spool isn't moving. I've had it apart and checked, and the transmission seems fine. Nothing visible is moving when it stalls. Thanks for the reply though! Any other suggestions? Sent from my iPhone using Tapatalk |
03-18-2015, 10:40 PM | #4 | |
Quarry Creeper Join Date: Nov 2013 Location: lethbridge,alberta, its mighty windy here!!
| Re: 3Racing winch problem Quote:
the 3racing winch will only pull barely over 1A in a stall on 2s, i tested mine to see what the stall current was for my winch controller these winches will run until they destroy themselves, and the controller would stop applying power if it was overcurrent rather than continue to run like it audibly does in the vid once load is applied. maybe the main gear on the motor itself could be too loose on the shaft and allow the motor to still turn once a big enough load has stopped the rotation of the gearbox, i have gone through a few gearboxes lately lol but the motor pinion always seems to be a very good and tight pressed fit, maybe see if you can grab a new motor/gearbox and see if that fixes the issue tony | |
03-18-2015, 10:42 PM | #5 | |
tony | |
03-18-2015, 11:16 PM | #6 | |
I guess it could also be inside the motor, that the rotor has come loose from the shaft!? How good is Locked Up RC's customer service? In case I want to get a new motor/gearbox. Thanks so far! | |
03-18-2015, 11:19 PM | #7 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Ive ended up with those on trade........ Super don't like em. Typically I gut them and use for a dummy winch and use a proper servo winch to move weight....... Kms k3 ...... Heyok 4 amp controller on straight 3s power.
03-19-2015, 09:53 AM | #8 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
If the motor or gearbox is bad we will send you a new one. As I stated in the other thread, please just shoot a ticket to our customer service with what you find and we will get you squared away: https://lockeduprc.3dcartstores.com/...tion=contactus Thanks! | |
03-19-2015, 09:59 AM | #9 | |
03-19-2015, 10:01 AM | #10 | |
03-19-2015, 11:02 AM | #11 |
Replacement is on the way. Sorry again for the issue! |
03-19-2015, 11:34 AM | #12 |
Fantastic! If only everyone had customer service like you.. Sent from my iPhone using Tapatalk |
03-19-2015, 04:01 PM | #13 |
| Re: 3Racing winch problem |
Tags |
3racing winch |
3Racing winch problem - Similar Threads | ||||
Commando Winch System & 3Racing winch motor upgrade! | Locked Up | Locked Up RC | 17 | 03-27-2015 08:09 AM |
Commando Winch System & 3Racing winch motor upgrade! | Locked Up | Vendors Electronics | 1 | 11-04-2014 07:59 AM |
3Racing Winch Problem | fiveo | Electronics | 19 | 09-15-2010 07:29 AM |
