05-02-2015, 06:39 AM | #1 |
Newbie Join Date: Mar 2015 Location: Sun Prairie
| Glitching w/ new setup
Previous setup: AE-2, axial 55t, stock gearing, savox 0251mg running on 2s turnigy 5600 /7.4v/50c New Setup: AE-2, RC4WD45t, stock gearing, savox 1283sg, running on 3s eco power 4200/11.1v/35c I am certain I need a bec to run this servo but the throttle is also glicthing/twitching. So is this also a result of the servo drawing to much voltage? This is my first go-round with 3s so just trying to cover the bases!! I know MOST guys running the ae-2 on 3s are NOT having problems but for those that r maybe, i'm missing something |
05-02-2015, 06:44 AM | #2 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: Glitching w/ new setup
The AE-2 isn't capable of running on 3s, but if you get an external BEC to handle the load of the internal BEC, you can run it no problems. The internal BEC isn't as effective at higher voltages. Google AE-2 on 3s |
05-02-2015, 07:06 AM | #3 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
You need a bec. Cc or heyok.
05-02-2015, 04:11 PM | #4 |
Pebble Pounder Join Date: Oct 2014 Location: bellville
| Re: Glitching w/ new setup |
05-02-2015, 06:35 PM | #5 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
I know people say the ae-2 requires a bec with 3s but I ran one on 3s for a while without a bec with no problems at all. I have since upgraded to a more powerful servo so I went with a bec but it worked fine with a stock servo. As for the glitch problem unplug the servo and see if the glitch problem continues. |
Glitching w/ new setup - Similar Threads | ||||
FXR glitching on dual setup, yes i have a BEC | jcboof | Electronics | 14 | 09-25-2010 12:04 AM |
glitching problem with my electronic setup | CS_BENOIT | Electronics | 1 | 07-14-2008 04:16 PM |
Is my setup right? CKRC Stage 2 setup - front axle castor | Miller Time | Axial AX-10 Scorpion | 14 | 03-01-2008 12:54 PM |
