07-01-2015, 10:34 AM | #1 |
Rock Stacker Join Date: Nov 2014 Location: Massachusetts
| removing a blown bearing from a traxxas motor? |
07-01-2015, 10:37 AM | #2 |
| Re: removing a blown bearing from a traxxas motor?
you could try the freezer.
07-01-2015, 10:45 AM | #3 |
i forgot to mention that i left it in the freezer all night i still wouldn't budge |
07-01-2015, 11:59 AM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
You'll have to heat it or find a bearing/gear puller small enough the grab the race. Heat will risk the stator, but aluminum expands and contracts at a faster rate than steel and should allow the bearing race to fall out. The freezer would do just the opposite, the aluminum can just squeezed the bearing race tighter. There are some Pilot Bushing/bearing pullers that might be small enough to grab the outer race, but I'm mot sure they'll reach that far into the motor. ...and I'm guessing that's one of their motors without the removable front plate. |
07-01-2015, 12:34 PM | #5 | |
| Re: removing a blown bearing from a traxxas motor? Quote:
07-01-2015, 04:11 PM | #6 |
Pebble Pounder Join Date: Oct 2014 Location: bellville
You might be able to run a blind hole tap in. It would bottom out against the case, and push the race out. |
07-01-2015, 04:57 PM | #7 |
| Re: removing a blown bearing from a traxxas motor? |
07-02-2015, 11:46 AM | #8 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
That looks like part of the bearing....only part of it http://www.docstoc.com/docs/43995732...r-Instructions https://www.youtube.com/watch?v=Y0td2aBxiHg http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSGY2 |
07-02-2015, 01:53 PM | #9 |
removing a blown bearing from a traxxas motor? - Similar Threads | ||||
Blown away by my Holmes Hobbies motor! | realsickclown | Electronics | 6 | 10-14-2013 09:36 PM |
help removing broken bearing from axle tube | GEARSCIENCE | EnRoute Berg | 15 | 12-02-2009 01:06 PM |
