09-11-2015, 07:40 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Will I burn out my rx?
will running a 7990th off the rx with the ccbec plugged into it burn up the rx? It's a spectrum 4100 rx. I'm worried about pulling that many amps through the rx.
09-11-2015, 08:36 PM | #2 |
Quarry Creeper Join Date: Jul 2015 Location: Winter Park Colorado, 8000Ft Elevation
| Re: Will I burn out my rx?
Running through the BEC eliminates the current going through the RX. Only the signal is going through the RX.
09-11-2015, 08:46 PM | #3 |
Receivers can handle plenty of amps. Spektrum is the only one I found spec for in the past and they are rated for something like 30 amps.
09-12-2015, 07:09 AM | #4 |
If you wire your BEC like I show in this link, you will eliminate any risk the the traces in the receiver. I don't believe there is much risk though. Also, if you decide to run more voltage to your steering servo, this is a good way of doing it because it doesn't over volt anything else: Yes, another one: BEC to HV Servo Wiring |
Will I burn out my rx? - Similar Threads | ||||
is this going to burn? | smokinloon | Electronics | 2 | 05-29-2014 09:41 AM |
Burn Baby Burn-Disco INFERNO | HotRodJosh | 1.9 Scale Rigs | 59 | 02-25-2011 12:30 PM |
Will it burn up? | logcruiser | HPI Wheely King | 1 | 05-10-2007 10:31 AM |
