11-08-2015, 10:07 AM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Chico, CA
| Replaced TX & RX and I blew out steering servo, lol
Well the good news is that my new Radio and receiver work great. Then of course, I turned up the Steering Rate on my TX too high and blew out my steering servo. Any good recommendations for a steering servo and horn that won't break the bank? Thanks |
11-08-2015, 11:16 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Replaced TX & RX and I blew out steering servo, lol
Ace! A 100 plus Oz is about 15 on line and water proof. They are made for / thunder tiger which I think is associated. They come in there 1/8 monster truck. My son has been using one for a year without any problems, I had it in 2 other cars
11-08-2015, 12:35 PM | #3 |
| Re: Replaced TX & RX and I blew out steering servo, lol Thanks snapon boy, would you mind linking the servo you're talking about? I don't see any Ace 200 oz servos listed on ebay.
11-08-2015, 12:48 PM | #4 |
Ace S 2008mg it has steel gears
11-08-2015, 12:53 PM | #5 |
| Re: Replaced TX & RX and I blew out steering servo, lol This one? It says it's 108oz, is that enough? Thunder Tiger CORP. -- HI TORQUE SERVO / S2008MG NO.8118 |
11-08-2015, 01:29 PM | #6 |
It's not the same case but I found the one my son has and the specs are wright, I'm sorry I thought It was 200. Long story short it works fine in my son's dingo with Mickey Thompson Baja claws . We went to a comp yesterday and he did almost as good as me. For 15 it's hard to beat. Jr has a cc bec set at 6 volts also. I keep some for spairs. |
11-08-2015, 01:46 PM | #7 |
Hey, no worries, if you think it'll work then I'll pull the trigger on it, appreciate it. Which servo horn or servo saver do you recommend? We've been through a few of them before, stripped out an aluminum one and a plastic one.
11-08-2015, 04:40 PM | #8 |
You can see on the bottom of the red wires where the Tower servo burned out, stinks real good: Last edited by Digital; 11-08-2015 at 04:51 PM. |
11-08-2015, 04:57 PM | #9 |
Newbie Join Date: Sep 2015 Location: Lisbon, CT
I'd stay away from ACE. The last ACE servo I had lasted 4 packs What's your budget? I personally have been running the Savox 1283SG in all my rigs. 416oz/in at 6V for $93. Never had any issues in 2 years of running them and it will push 7" MT tires around with ease. Make sure you adjust and keep an eye on your dual rate or set endpoints on your TX if equipped or you'll burn out any servo eventually |
11-08-2015, 05:53 PM | #10 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Replaced TX & RX and I blew out steering servo, lol Quote:
Savox 1283 is a pos. Don't make that good of power...... brown out easily and burn up. Many problems with them. 1270 is a better servo $84 directly from savox. | |
11-12-2015, 10:48 PM | #11 |
The point about setting your endpoints is a good one. If you can set them do it. As for brands of Servo I use Ace and hitec and I have a Holmes Hobbies. If your going to run a hi torque Servo get a bec.
11-12-2015, 10:55 PM | #12 |
Thanks bud, I picked up a Castle BEC and one of those new Promodeler v3 (420oz) servo's |
11-14-2015, 08:04 AM | #13 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
So far I have heard decent reviews about the pro modeler servo's, and you can't go wrong with a Hitec either. I know you already ordered the pro modeler, but pick up a solar D772 for a spare. I have been using one in a rig for almost two years and still going lol. If you happen to burn up this servo you ordered at least you have a cheap replacement until you get another one. Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear Cheers, Wade |
Replaced TX & RX and I blew out steering servo, lol - Similar Threads | ||||
Steering & servo setup | Hardline | Electronics | 1 | 03-03-2015 08:55 PM |
exceed mad torque, replaced ESC, now steering is very weak | uglyjeepoffroad | Newbie General | 4 | 12-05-2013 07:27 PM |
Replaced steering servos...now problems????? | JC-8 | Traxxas Crawlers | 15 | 07-12-2013 06:40 AM |
Need help with weird DX3 & Steering Servo Issue | MtnBkr | Electronics | 6 | 03-21-2010 08:00 PM |
