04-19-2016, 01:15 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Bus bar options or ideas needed
I've done some searching and found one thread that discussed using a bus bar for wiring a bunch of items in a scaler. There wasn't a clear resolution so I wanted to pose the question again. Does anyone make or are there any good homemade bus bar ideas out there? I'm building a scaler that will have 7 led bars, 2 winches, 2 steering servos, a sound card, and who knows what else. I plan to run each steering servo off its own bec, the winches will run off 1 esc for control, with a double throw switch to select which winch wil be controlled. Plus a castle mmp with a brushless motor. All powered by a single 3s batt. That's at least 12 items running off one circuit. Normally I would have splices throughout the truck to make this work but wondering if a bus bar would be a better solution. From what I've read, interference can be an issue. Any feedback on ideas that have worked or not worked for you all is appreciated. Thanks. |
04-19-2016, 01:25 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: Bus bar options or ideas needed
You'll probably need something like this. There a ton of varieties pin numbers to choose but you'll need to watch the size, but they don't seem to get too large. Multi-Circuit connector |
04-19-2016, 01:43 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
| Re: Bus bar options or ideas needed |
04-19-2016, 01:49 PM | #4 |
RCC Addict Join Date: May 2015 Location: Price Twp.
Try a piece of circuit board. You can solder jumper or draw your own paths. or https://www.google.com/search?q=circ...terminal+block Last edited by Ditchrat; 04-19-2016 at 01:55 PM. |
04-19-2016, 02:10 PM | #5 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
I use "european terminal" for when I want to basically make a big splitter for lots of lights and such: european terminal | eBay I just cut off a pair, clamp down power in on one side, and then I can easily add/remove wires from the other side. |
04-19-2016, 03:27 PM | #6 |
04-19-2016, 03:33 PM | #7 |
RCC Addict Join Date: May 2011 Location: at home
found these guys a while back and they have several interesting "things". something like this will let you build a strip to handle multiple connection 0.1" Servo Strip PCB when used with something like this Gold Triple Row Female to Male Adapter Header - 120 Pin there are several possibilities there, just look around. I could not sleep after I found this site for all the ideas I was getting. haha look at the examples they show with each product |
04-19-2016, 04:03 PM | #8 | |
| Re: Bus bar options or ideas needed Quote: I can make it with more pins if you need it. | |
04-19-2016, 08:36 PM | #9 | |
Thats nice and small. This stuff can be great to work with. Comes in male to male, female to male and female to female. You can solder the pins into the board, leaving the other end open. Leds, once you cut them even, will fit right into the female end. Female ends and male ends will fit into servo wire. They come in different lenght, and you can break them away into pairs. You can even pull the pins out and insert them in servo connectors. I use these all the time when testing and setting up leds prior to soldering and hard wiring things. I have several small scale rigs set up using these plugs and not even bothering to solder things up. If I want to change from white lights to red I simple pull out the leds and put new ones in. If I want to run 10 pairs I simple cut an 11 x 2 piece of board, insert the males into the board. On the back side I use a piece of solid wire to jump them and solder it up. Add input wires, then liquid electrical tape the whole thing together, clean it up with shrink wrap and done. Last edited by Ditchrat; 04-19-2016 at 08:38 PM. | |
04-20-2016, 08:19 AM | #10 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Heyok bus bar works great ! If you have any old receivers you can cut them open and use the bus bar from them for free. All the hot and ground pins are bonded so it does exactly what you need. Look in my build thread ( sloppy, stiffy or prego) cant remember if I renamed the truck everytime I rebuilt it on here.... I have done the rx thing many times with old futaba magnum and other old rx's I had laying aroumd from the 80's and 90's |
04-20-2016, 09:46 AM | #11 |
I saw someone use serial connectors also. These look pretty solid. I might have to look into this as well. Serial connector |
04-20-2016, 11:19 AM | #12 | ||||
04-20-2016, 11:44 AM | #13 |
04-20-2016, 01:06 PM | #14 |
04-20-2016, 03:09 PM | #15 |
Bus bar options or ideas needed - Similar Threads | ||||
Need options and ideas for throttle /reverse situation | havik | Electronics | 0 | 03-31-2016 07:29 PM |
HELP - Need ideas for sway bar install | WesTX | General Crawlers | 5 | 12-20-2014 05:52 PM |
Light Bar options.. Help! | GoSpeedRCerGo | Axial SCX-10 | 2 | 04-23-2013 06:22 AM |
Honcho bumper ideas and options | Kykrawler | Axial SCX-10 | 22 | 01-17-2013 09:41 AM |
light bar options | Ruggalo | Axial Wraith | 8 | 12-17-2012 01:19 AM |
