06-10-2016, 04:31 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| Which ESC to pull red wire off?
Running extremely modified racing clodbuster, 2 tekin brushless motors, 2 Hitec 7950 servos, 2 CC Sv3 sidewinders, and 2 CC Bec using Bec Bypass Adapter. Just got it all wired up and seems all systems working. The only thing is removing the red wire from one of the ESC. So, the question is, does it matter which ESC to pull out the red wire? Front or Rear, or don't matter as long one has its red wire pulled. I'm sure it's is don't matter as long one has its red wire pulled. just wanna cover my ass, its a expensive project. |
06-10-2016, 04:56 PM | #2 |
| Re: Which ESC to pull red wire off?
I think I answered my own question. Neither need red wire pulled because I am using Bec Bypass adapter for both servos. But still would like an answer, as if I did not use any Bec Bypass adapter. |
06-10-2016, 05:04 PM | #3 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
Either one needs to have a red wire pulled, doesn't matter which. You need to pull one so the internal BECs in the ESCs don't fight each other. |
06-10-2016, 05:44 PM | #4 |
| Re: Which ESC to pull red wire off? |
Which ESC to pull red wire off? - Similar Threads | ||||
Castle link on esc without red wire | Tgates | Electronics | 6 | 02-12-2014 08:17 PM |
Dual esc-Do i remove red wire???? | losikid | Electronics | 7 | 03-29-2010 11:24 AM |
How do you remove red wire off esc? | boisetrucker | Electronics | 3 | 05-18-2009 09:14 PM |
How do I pull out the red wire on my FXR? | BigB_117 | Electronics | 7 | 03-16-2009 07:36 AM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
