08-26-2016, 10:16 PM | #1 |
Newbie Join Date: Jul 2016 Location: Citrus
| BEC and 4ws dual servos, intermittent power
Long story short, I am getting intermittent/glitchy power when running both servos off a y-harness and a Castle 10-amp BEC. Here is my gear: Flysky HV receiver FS-GR3F (4.0 - 8.4V) Castle 10-amp CC-BEC set to 7.4v Dual HItec HV HS-7950TH servos (rated at 7.4v) plugged into a Y-harness I believe it to be my BEC at fault; when I run a straight 2s pack to my receiver, I have no issues. Should I raise the voltage of my BEC, or does it simply not put out enough amperage? Is it safe to run power from my main 2s pack to the receiver? |
08-27-2016, 01:41 PM | #2 |
| Re: BEC and 4ws dual servos, intermittent power
Lowering the voltage will allow more amperage. Try 6 volts. Or wire the servos directly to the battery. |
08-27-2016, 01:55 PM | #3 |
| Re: BEC and 4ws dual servos, intermittent power They are HV servos, I kinda bought them to run them at 7.4 lol :-P. Would running straight power from the main pack to the receiver give the same results? Any issues there?
08-27-2016, 02:15 PM | #4 |
Put a glitch capacitor on, it might be just enough to keep the servos fed
08-27-2016, 02:16 PM | #5 |
I've run a 7950 at 6 volts for years and think ~430 oz of torque is plenty. Same results as what? |
08-27-2016, 03:23 PM | #6 |
| Re: BEC and 4ws dual servos, intermittent power |
08-27-2016, 03:28 PM | #7 |
08-27-2016, 04:04 PM | #8 |
Wiring the servo directly to the battery will initially supply 8.6 volts. It will also allow a large amount of amperage to be delivered. Use the ESC's built in BEC to power the receiver.
08-27-2016, 05:31 PM | #9 |
| Re: BEC and 4ws dual servos, intermittent power My ESC BEC only supplies 5v, I want to run my servos on 7.4. I know it can be done, just need to figure out the best way.
08-27-2016, 08:48 PM | #10 |
Quarry Creeper Join Date: Nov 2013 Location: lethbridge,alberta, its mighty windy here!!
is the bec powering the rx as well as the servos? tony |
08-28-2016, 02:37 AM | #11 |
Yes, Im running the castle bec to the receiver. I have run hv servos off of a 2s lipo in other applications, just not off the main power pack. Im wondering if anyone does this without issue? |
08-28-2016, 01:49 PM | #12 |
if you remove the bec from rx and solely use esc's built in bec to power rx as eepee suggested and dedicate the bec to just the servos with a bypass adapter( didnt see he had already asked that last night when i asked after, tired lol) that should alleviate some/most of the glitching as the rx will not end up browning out with 2 hv servos drawing direct from bec as opposed to drawing from bec via rx ( pcb power traces in rx are not great for high current draw ). definately keep the glitch capacitor in place regardless as a redundancy measure just in case. if you have run hv servos from direct 2s before then it shouldnt be any different doing it this time, just more wiring up to do, also your y harness if its just a standard gauge servo wire maybe look into upgrading it for something a little more like a 22AWG or bigger wire just to make sure that it can handle any peak current demands. tony |
08-28-2016, 02:38 PM | #13 | |
| Re: BEC and 4ws dual servos, intermittent power Quote:
My main concern, and I havent done this before, is using the main pack to power BOTH MOTOR AND RX/SERVOS. Any forseeable issues there as far as power draw? It is a 20C-30C 2s pack. I was hoping to hear from somebody who is doing this, but I guess I may be the guinea pig... Also in case of any questions, I read this servo is designed to run off 2s power. https://www.servocity.com/hs-7950th-servo I thought of doing your first suggestion initially, a little more wiring to do but it is an option. And sorry EeePee, I wasn't sure if this was what you meant for sure. Last edited by chalmene; 08-28-2016 at 02:49 PM. Reason: capitalization | |
08-28-2016, 02:50 PM | #14 |
Far from the guinea pig. No issues. Been done for a dozen years.
08-28-2016, 03:10 PM | #15 |
| Re: BEC and 4ws dual servos, intermittent power Right, I was kinda hoping to hear from folks doing it this way though. Just nice to have feedback, being paranoid I guess. Anyway, thanks for the help guys, I think I'll go the single 2s pack / no BEC route then.
BEC and 4ws dual servos, intermittent power - Similar Threads | ||||
Dual servos 1 bec help | cyberhog05 | Electronics | 17 | 03-01-2016 07:44 PM |
dual steering servos, a cc bec, a y-harness, and 4 cells of lipo power… | mudholestomper | Electronics | 3 | 10-23-2015 08:49 AM |
4ws crawler with dual bec | cyborgx | Electronics | 0 | 06-08-2014 02:52 PM |
dual bec with dual servos? | t-oda | Electronics | 10 | 01-22-2011 10:35 AM |
wiring diagram for dual esc's, dual servos, bec, and one battery??? | jedsled | Tamiya Clod Buster | 6 | 11-13-2008 07:36 AM |
