10-09-2016, 12:11 AM | #1 |
Newbie Join Date: Sep 2016 Location: chino valley
| Xerun 17.5 low top end
So I'm helping a friend of mine out, we've installed the xerun juststock system in his wraith and it has the 17.5 motor. When everything was done installing and came time to run the rig is slower than when it had the 20 turn motor in it. Are we missing something as far as programming or is it possible that he got a faulty unit???
10-09-2016, 06:42 AM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Xerun 17.5 low top end
The just stock setup is for blinkey light racing. IMHO. So a lot of the settings are fixed. However go up 2 teeth on the pinnion, and see if that helps. 149 r/c worx team driver |
10-09-2016, 08:42 AM | #3 |
Watch your temp. 160 max 149 r/c worx team driver |
10-09-2016, 11:39 AM | #4 |
I know we could gear it, but out issue is that even out of the box his brushed motor seems to have more top end with the same gearing. That doesn't seem right I have a brushless castle s3 in my crawler and his won't even come close to keeping up with me
10-09-2016, 11:55 AM | #5 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Xerun 17.5 low top end The difference between a 20t brushed and the Xerun 17.5 isn't that significant (~3216 kV vs 3650 kV, so only around 10%). Get two or three larger pinions and watch your motor temps like snapon suggested.
10-09-2016, 01:14 PM | #6 |
I see I thought since it was a brushless setup it would be like the castle in a way maybe he'll have to get the castle then
10-09-2016, 01:26 PM | #7 |
Newbie Join Date: Jan 2015 Location: Quebec City, Canada
A brushless 17.5t is comparable to a 27t brushed motor. Your brushed 20t is probably closer to a 13.5t brushless motor. Gearing up will bring you to the speed you were aiming, but to the cost of some heat and lower axle torque. In my opinion the beat combo for a wraith / bomber is a sensored 4 pole. Holmes Hobby or Tekin, the choice is your! I did run a bomber with a Hobbywing SCT pro and a 4000kv 4 pole sensored motor (on 2s). It wasn't as refined as a Tekin setup, but it was hauling!! Sent from my W330 using Tapatalk |
10-09-2016, 01:48 PM | #8 |
| Re: Xerun 17.5 low top end |
10-09-2016, 02:01 PM | #9 |
You're not going to get top end from any 17.5 turn motor. Brushless motors are more efficient, but not really any faster than brushed motors. HobbyWing also makes great, inexpensive, brushless motors. I believe the RC Gear Shop motors sold on Tower Hobbies are just rebranded HobbyWing motors. |
10-09-2016, 03:45 PM | #10 |
10-10-2016, 02:18 AM | #11 | |
Pebble Pounder Join Date: Mar 2016 Location: westminster
| Re: Xerun 17.5 low top end Quote:
10-10-2016, 03:16 AM | #12 |
Rock Stacker Join Date: Sep 2010 Location: Indonesia-West Java
may be the cause of esc. hw justock only 45 amp |
10-10-2016, 07:58 AM | #13 | |
The 17.5 motor you installed is 2100kv per their website. Comparing to a 4600kv motor it is going to be far slower. | |
10-10-2016, 08:20 AM | #14 |
| Re: Xerun 17.5 low top end This, and I stand corrected. The motor most definitely is 2100 kV per their website (not 3650 like I ass-umed). It's not even going to be half as fast as the Castle.
10-10-2016, 01:32 PM | #15 |
Thank you guys seems like we were mislead by our lhs gonna start doing more research before I but on things I am unsure of
10-10-2016, 07:17 PM | #16 |
Newbie Join Date: Sep 2016 Location: Texas
Just keep in mid, the ez run is designed for on road lighter weight or offload 2wd 10th scale buggies. So the heavier weight and the 4wd will more than likely severely shorten the life of the system. And/or "let the genie out".. Send a little more$ and get with HH or MMP and a 3300kv. It will make your runtime more enjoyable and a heck of a lot less head ache.
10-10-2016, 08:40 PM | #17 | |
Xerun 17.5 low top end - Similar Threads | ||||
Back end sitting low | DevonJD | Newbie General | 4 | 12-03-2015 05:19 PM |
New MMP 1c and some low end cogging | concretejungle | Electronics | 31 | 02-27-2011 09:47 AM |
jerky motor in low end | matador88 | Electronics | 2 | 05-13-2010 06:39 PM |
