08-10-2017, 08:26 AM | #21 | |
| Castle Link Quote:
Does that work for you ? Castle and others say that does not work, that's why this was made. Or are you unplugging the esc out of the rx box Edit..... I'm thinking a Y cord. Hang up and Drive Last edited by mikemcE; 08-10-2017 at 09:25 AM. | |
08-10-2017, 11:19 AM | #22 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Re: Castle Link |
08-10-2017, 11:35 AM | #23 |
| Re: Castle Link
Best connector choice is the Castle Duo-Connect. Check their site for details... I'm at work, so I can't cut/paste right now...... |
08-10-2017, 01:54 PM | #24 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Castle Link Ya whatever makes it the easiest for you to get it unplugged and castle link hooked up. You could keep it near a side panel so you can undo a panel and reach it that way. You'll only mess with it maybe a few times after you get it running.
08-10-2017, 04:19 PM | #25 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Castle Link Quote:
It doesn't work as a Y connector. I think what 84yoda meat was to use an extension so you can easily unplug the esc to use the link. | |
08-10-2017, 04:45 PM | #26 | |
Castle Creations Castle-Link Quick Connect Duo | TowerHobbies.com I dont have an X so I use the single. Castle Creations Castle Link Quick Connect | TowerHobbies.com | |
08-10-2017, 07:19 PM | #27 |
| Re: Castle Link
I knew there was a reason why I should've waited to post until I was home! I have a Mamba X and a Mamba Monster X, forgot about the Duo-Connect details. (Whoops!) |
08-10-2017, 09:14 PM | #28 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Castle Link
I have the field card and have only used it that way once. It is pretty limited on function. I normally just use my laptop for programming. If you have your RX in a sealed box and cant get to the connector easily, just buy a short servo extension for the ESC/RX connection. You can then just disconnect the ESC from the extension and hook it to the Castle Link quickly and easily. No need to buy that other thing really. |
08-10-2017, 09:42 PM | #29 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: Castle Link
I like the clean look of the quick connect duo. Just using the extension seems like it would work fine and Castle is not recommending it probably just so we can spend our money on the fancy looking connector, fine by me Castle.. Wouldnt really need it for my Traxxas rigs, but man that claimed waterproof box thats in Axials 10ii's, its a requirement if you want to do some programming. 4 long and tight cap screws followed by the rubber gasket, I bet it really simplifies things. |
08-11-2017, 02:02 PM | #30 |
| Re: Castle Link
Maybe someone can answer this, if not I'll play with it when it actually arrives, but if I get another castle esc, can the one castle link program multiple esc? Reason I ask this is because I have a tuner for my 1:1 jeep and its connected to just my jeep. Nobody else can use it until I return my jeep to stock tune and then it can be rebinded to another jeep. Furthermore, once I download the castle software onto my computer, does it have the ability to store more than one tune? Say I want a bashing tune and a crawler tune, I know my MMP does not have the ability to store two like the mamba X does, but does the software on the PC? |
08-11-2017, 02:08 PM | #31 |
| Re: Castle Link
Yes, you can program as many as you like. It's not limited to one esc. Anything with castles name can be programmed.
08-11-2017, 02:28 PM | #32 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
While it doesn't have the AUX wire adjustment of the Mamba X, all Castle ESC's can save tunes in Castle Link. You can setup a tune and then save it to your computer from the file menu and then setup another one and save it. Then just load the file you want and update the settings to flip between tune profiles. | |
08-11-2017, 02:36 PM | #33 | |
The quick connects have a chip in them that detects if power is coming from the Castle link, and disconnects power from the RX so the USB is only powering the ESC. You also don't need to buy the Duo if you are using a Micro-X, Mamba-X, or Monster-X. You can use the regular and then run the AUX wire straight to the RX. The Duo just gives a pass through for the AUX wire that can disconnect the second BEC line. It is needed on the BEC 2.0, Mamba XLX, Talon 120, and Phoenix Edge Line. | |
08-11-2017, 02:53 PM | #34 | ||
now this is customer service!!!! | ||
08-11-2017, 05:16 PM | #35 |
| Re: Castle Link
Robert and Thomas are a tremendous resource and asset to Castle ! Hang up and Drive |
08-11-2017, 08:23 PM | #36 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
| Re: Castle Link
Hey Robert, what are the chances of getting a mobile app? Now that we can use a OTG cable, there is much more potential to do a lot more tweaking in the field without dragging a laptop around. Please? Pretty please? |
08-11-2017, 09:45 PM | #37 | |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
Sent from my Pixel using Tapatalk | |
08-13-2017, 01:07 AM | #38 |
| Re: Castle Link
Hope that word is getting around the offices of Castle about how much we really want an app for our cellphone format devices. I'm sure its on their drawing board, just hope that they know the demand for it is HIGH, so theres nothing to worry about.. get the developers to work!
08-13-2017, 01:18 AM | #39 | |
08-13-2017, 10:16 AM | #40 | |
