Thread: HH Torquemaster BR Mini Dual connections
Old 10-04-2017, 05:27 PM   #1
Default HH Torquemaster BR Mini Dual connections
I just got a HH Torquemaster BR Mini Dual /w a CC BEC attached for a XR10 and am confused about the 3 small receiver style plugs where they plug into. 1 from BEC is a larger gauge wires than other 2 coming from ESC and none are labeled. Where do the 2 smaller connectors go? 1 Has to be throttle on rec but what is the other for? I do have a HH RX Bypass Adapter, so BEC connector goes there.
White cobra is offline   Reply With Quote
Old 10-04-2017, 06:53 PM   #2
Default Re: HH Torquemaster BR Mini Dual connections
Both of those go into the receiver. Each ESC has a separate receiver plug. Most radio setups your front motor ESC will go into channel 2 and your rear motor ESC will go into channel 3. I know my Futaba 4PLS radio the rear motor ESC goes into channel 4 to use their pre-programmed channel mixing but that's not the normal case. You'll probably be using channel 2 and 3. Channel 1 should be your steering servo as usual. You'll need to pull the power wire on the second ESC that isn't running through the bypass adapter.
ElChupacabra is offline   Reply With Quote
HH Torquemaster BR Mini Dual connections - Similar Threads
Why wont my Holmes TorqueMaster BR Mini Dual stay in nautral ? g-jero Electronics 7 06-12-2014 02:19 AM
TorqueMaster Mini Blazerbogger Electronics 14 09-01-2010 04:13 PM
Dual TorqueMaster BR-XL's?? 53 willys EnRoute Berg 4 12-10-2009 08:34 PM
