01-04-2018, 10:47 AM | #1 |
Newbie Join Date: Jan 2018 Location: Cold
| GT3C update issue, Swim connection error
Trying to update my FS-GT3C-m Rev 1.6 using an ST-link V2, I originally had the wires hooked up near the transmitter as per the videos, I got a swim error, checked all connections all where fine. I want to note that the GT3C is different then the GT3B, all pins are still there, plus a few [IMG][/IMG] I then found the pinout diagram for the STM8S-Discovery board SWIM connector to attach it like overkillRC does [IMG][/IMG] I then connected everything following this and overkillRC video and picture instructions to get the same result, Error on SWIM [IMG][/IMG] This is then end result, the blue wire is not connected but is the reset wire (not needed but overkill had it hooked up) [IMG][/IMG] Does anyone know a Fix for this? a possible solution? or am I going to have to get an STM8S-discovery board in order to flash my GT3C, I can provide any other pictures or info needed Thanks Guys! Red |
01-04-2018, 10:55 AM | #2 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: GT3C update issue, Swim connection error
Were you able to us that ST-Link on another transmitter, as in have you verified it's working? I'm not sure if you looked at your own pics, but they tell us nothing. What color wires connect to what pins on your ST-Link? This wire diagram worked for me: |
01-04-2018, 11:10 AM | #3 |
[IMG][/IMG] I have not used this st-link before it was new out of the package (i know that does not mean much) photobucket wont upload my new image, when it does i will link it yellow 5v, red swim, green ground. Last edited by R3DRumG33k; 01-04-2018 at 11:14 AM. |
01-04-2018, 11:25 AM | #4 |
Your connections on the ST-Link are incorrect, GND and SWIM are swapped. That middle pin in the notch is GND, the pin to the right is SWIM. Also ditch photobucket & switch to imgur.com, it's like the difference between a 1970's transmitter and a hacked 2018 transmitter. |
01-04-2018, 11:40 AM | #5 |
[IMG][/IMG] They are not on this controller...i tried to swap them for shits and grins and same outcome Last edited by R3DRumG33k; 01-04-2018 at 11:50 AM. |
01-04-2018, 12:06 PM | #6 |
That's really odd, most ST-Link v2 pics I find have a different pinout like that below. Mine actually looks identical to this pic with the "M" logo. Maybe take a DMM and probe the pins when it's plugged in, verify the 5v and GND are correct. It's possible the actual pinout doesn't match the etched pinout. If the radio doesn't power up when you plug it in they're obviously not right. It could just be bad hardware, too. This link indicates there are multiple types of "V2": https://community.st.com/thread/30691 Last edited by Hydrocarbon92; 01-04-2018 at 12:09 PM. |
01-04-2018, 12:18 PM | #7 |
So either my ST-LINK V2 is just bunk...or I got one that is possibly to old of a version...or the Rev 1.6 just can not be flashed? I guess I will order another ST-LINK, or should I just get the STM8S- DISCOVERY board? Ill probe around with a multi meter here in a few just to confirm things on the ST-LINK. the radio powers up and beeps like is said should happen Thanks Red Last edited by R3DRumG33k; 01-04-2018 at 12:29 PM. |
01-04-2018, 12:30 PM | #8 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: GT3C update issue, Swim connection error Quote:
01-04-2018, 01:14 PM | #9 |
RCC Addict Join Date: Jun 2016 Location: Germany
as i hacked my gt3b it worked after i connected all 4 and i had to switch the tx on.
09-13-2018, 06:49 PM | #10 |
Newbie Join Date: Jan 2017 Location: Newfoundland
I have the same ST-Link V2 as R3DRumG33k, same pinout. Don't have my GT3C yet... Was this issue resolved? |
12-20-2020, 01:15 AM | #11 |
Newbie Join Date: Jun 2020 Location: GB
Bit of a thread resurrection. I have the same programmer (same pinout) and a v1.6 GT3C radio. As soon as I connect power and gnd it starts beeping. Doesn't matter which way swim and rst go, either the way the guide points or the way the programmer says, just beeps and won't read in the software. Sent from my Pixel 5 using Tapatalk |
GT3C update issue, Swim connection error - Similar Threads | ||||
What the #$&@?! Flysky gt3c and ae-2 issue | jebster | Electronics | 31 | 03-21-2017 12:19 PM |
BRmini dual with GT3C hacked : dig issue | Bergm@n | Electronics | 6 | 12-03-2015 01:54 PM |
FXR update issue | crash | Electronics | 2 | 08-31-2009 11:06 AM |
Up for a swim | 1BadJeepBruiser | Chit Chat | 60 | 08-14-2007 03:34 PM |
