Thread: motor conversion
Old 01-23-2018, 06:02 PM   #1
Default motor conversion
i have searched but came up lost.is there a chart to go by to convert a 550 to a 540 or vice versa by the number of turns or does anyone know for sure what the difference in the two would be?example:17t 550=how many turns 540 to replace it.thanks
thead is offline   Reply With Quote
Old 01-23-2018, 07:15 PM   #2
Default Re: motor conversion
this is a decent start
https://holmeshobbies.com/motor-recommendations
allanon1965 is offline   Reply With Quote
Old 01-23-2018, 07:26 PM   #3
Someone correct me if im wrong but i think the turns on 550 and 540 are equal unless it's a 3-slot vs 5-slot armature.
The 550 is just longer so it has more torque and less heat.
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 01-23-2018, 09:12 PM   #4
Based on the chart a 550 will have the same speed as a 540 with ~30% more turns. Longer armatures use longer wire [per turn], and more wire length results in slower speeds.
Hydrocarbon92 is offline   Reply With Quote
motor conversion - Similar Threads
M04RR (Rear motor conversion) OSRC Non Crawler RC's 9 08-11-2017 01:04 PM
Drill motor conversion RaceMod Electronics 19 08-14-2014 05:38 PM
front motor conversion help! c0bra Non Crawler RC's 10 04-26-2013 09:41 PM
540 conversion and motor ??? WestTxRc Redcat Crawlers 1 11-26-2011 11:41 PM
motor ???? for Moa conversion losiredcatcrawler Team Losi Comp Crawler 8 04-05-2010 06:27 PM
