Thread: light from batt port?
Old 03-14-2018, 07:37 AM   #1
Default light from batt port?
can i use the batt port on my receiver to power lights??
midwest_rippa is offline   Reply With Quote
Old 03-14-2018, 10:30 AM   #2
Default Re: light from batt port?
Yup. That port provides power at whatever voltage the BEC is supplying the RX.
What ESC are you running? If it is an RTR ESC there might be power issues that could cause a brown out.
Greatscott is offline   Reply With Quote
Old 03-14-2018, 01:21 PM   #3
im using a roc412 with rsgen2 esc so no power issues with me lol. thanks for the help!
Old 03-14-2018, 02:19 PM   #4
Dont forget about it, you can burn your car down.
Ditchrat is offline   Reply With Quote
Old 03-14-2018, 04:21 PM   #5
2 or 3 6v lights wont draw enough power for that hopefully tho. right?
Old 03-14-2018, 04:27 PM   #6
Natedog's Avatar
3 or 4 leds should be fine, just be careful if it's a super bright lightbar, read the amp draw(s) for the lights, add them up, check against ESC/RX capability and leave a little buffer.
light from batt port? - Similar Threads
Port orange old man 52 Florida 58 01-08-2020 10:27 AM
Anyone near Port Angeles?? Dagwood Washington 5 11-06-2015 12:21 PM
Port Lavaca,Tx twentyfootdaredevil Texas 6 12-30-2012 09:46 PM
Can Bind Port Be Used as Batt Port? alexchen86 Electronics 3 08-18-2010 06:24 AM
