05-15-2018, 02:39 PM | #1 |
Newbie Join Date: Apr 2018 Location: Hamilton, NJ
| Radio
is there a way to convert a radio from using eight AA to four AA
05-15-2018, 04:25 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: Radio
No.
05-15-2018, 04:55 PM | #3 |
| Re: Radio
No, but you can replace the 8 AAs with a 3s life pack.
05-15-2018, 07:01 PM | #4 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: Radio
Yes and no. Most 8-cell radios are 5v circuit boards and use a wasteful linear regulator (aka BEC). The problem is battery alarms look at the pre-regulator voltage. In the case of hacked GT3's, you can change adjust the battery alarm voltage and use lower voltage (1-1.5v above board voltage). In other radios it will just keep warning you low battery. You could even run it off a single cell by using a boost regulator - I use a few for 12v LED lights. The best bet is just changing its onboard linear regulator with a switch-mode regulator. You'd go from 30-50% efficiency to 85-95%, doubling battery life. GT3 guys usually use an overpriced monolithic reg, but any BEC will work if it's output is what your board uses. |
Radio - Similar Threads | ||||
Radio ideas: surface radio + full mixing of front/rear throttle | karajabola | Electronics | 6 | 11-21-2014 08:17 PM |
Aux channel dig radio/servo question DX3R radio... | Master Basher | Electronics | 0 | 02-10-2014 12:29 PM |
What radios are you guys using? stick radio or pistol grip radio?? | yellowpasta2000 | Newbie General | 14 | 11-28-2009 09:10 AM |
Convince me why I should buy a 3pm-x radio over a 2pl radio | BadRockNoCookie | Electronics | 6 | 11-13-2009 06:23 PM |
